Do you mean rocker rails? Those are the aluminum reinforcing strips that run along under the rocker panels below the doors. They protect the panels from grounding especially on lowered cars.
Roller rockers are rocker arms. Roller rockers is short for roller rocker arms. They are called roller rockers since they pivot on roller bearings. They reduce friction and therefore they increase horsepower over non-roller type rocker arms.
In addition to this, the rocker arms can have roller tips that roll over the value tips instead of scrubbing them.
In case you're wondering, all LSX engines have roller rocker arms with roller tips. They also use roller lifters with the camshaft.
Well there you go. You learn something new every day. Thanks
Well i have a head cam car and was wondering if changing out the lifters and or the rocker arms would add any horsepower.
I assume by "head-cam car" you mean the engine has aftermarket heads and a cam. If it's an LS1 then I'm sure it's using the stock roller rocker arms. I also assume that whoever put the cam in, replaced the stock roller one with another roller one.
Yes there are better quality roller rocker arms than came with the LS1, but I seriously doubt you would notice much if any difference changing them out.
Hold the phone!!!!
LS1, LS2, LS6 and LS7 motors do NOT come with roller tipped rockers.
Hold the phone!!!!
The LT4 engine came with full roller rocker arms provided by Crane and stamped with the Bowtie emblem. The roller rocker design enables higher revs with less heat and friction.
The stock stamped rocker arms on the LT1 were 1.5 where the LT4 came stock with 1.6. The reason to go larger or longer is an old cheater trick - the higher lift, the longer the valves stay open and/or closed adding a few extra ponies. The only concern is to make sure the valve springs can take the higher lift and RPM.
The LS1 comes standard with 1.7 lift. and after market kits at 1.85.
