road noise
Old May 24, 2007 | 10:29 PM
Yeates 1's Avatar
Yeates 1
3rd Gear
Default road noise
I am a first time owner of an '01 C5 coupe, 6 spd, mag red, love the car, only thing I have found wrong is on a rough surface road or expansion joint road it has lots of road noise. Any good safe ideas to cut doun on noise??? Yeates 1
Old May 24, 2007 | 10:37 PM
Bill Vett's Avatar
Bill Vett
Do away with the stock runflats or buy a better quality runflat tire.
Old May 24, 2007 | 10:39 PM
mud flap's Avatar
mud flap
Old May 24, 2007 | 10:47 PM
Ms Eliz's Avatar
Ms Eliz
Old May 24, 2007 | 11:17 PM
R Devil's Avatar
R Devil
Ditto with all above.
Old May 24, 2007 | 11:18 PM
DeeGee's Avatar
DeeGee
If you want run flats the Michelin Pilot Sport AS ZPs are a good improvement. If you can live without runflats there are a number of cheaper and quieter options out there.
Old May 24, 2007 | 11:19 PM
Install some insulation under the carpet and get non-runflat tires.
Old May 24, 2007 | 11:25 PM
Firethorn55's Avatar
Firethorn55
You can search the threads on this topic. There has been alot of discussion on it and what can be done. One of the quickest, easiest and cheapest things you can do is by some fiberglass insulation (R-13) and fill up the three storage compartments with it. It will cut the noise volume down by at about half. I bought a roll at Home Depot for under $ 11.00 and made 3 layers per compartment. Huge difference.
Old May 25, 2007 | 12:05 AM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
What Bill said,,,,,,,,,,,,,,,,,,,,,,,,,,Or move to Virginia!
Old May 25, 2007 | 05:55 AM
Black 'n Tan's Avatar
Black 'n Tan
St. Jude Donor '07
I agree, the roads here are INCREDIBLY SMOOTH. I notice every time I go back to the Northeast! I thought my car rode nice, until I get out of the area!
John
Old May 25, 2007 | 09:00 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
If you go to Virginia, keep to the southern end. Up north the roads suck!!
Old May 25, 2007 | 09:20 AM
LMB-Z's Avatar
LMB-Z
If you are looking for a quick fix, just fill up the rear compartments with towels. It will help quite a bit. Then you can work on the insulation.
Old May 25, 2007 | 10:08 AM
rws.1's Avatar
rws.1
Ditch the run flats, insulate the storage compartments and buy and aftermarket exhaust...Borla or B&B....
Old May 25, 2007 | 10:32 AM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Insulate the wall behind the seats and inside the wheel wells.
Old May 25, 2007 | 09:15 PM
dezcapt51's Avatar
dezcapt51
Borla dual quads !!!!!! What road noise
Old May 25, 2007 | 09:18 PM
zTrek's Avatar
zTrek
Yep, I did the same thing and the noise reduction is amazing. A lot of the noise you are hearing is "resonance" that is created in those rear storage compartments. The fiberglass insulation has quite a dampening affect. Not only does it diminish road noise, it also reduces exhaust drone. Good luck!
Old May 25, 2007 | 09:33 PM
99 White FRC's Avatar
99 White FRC
I agree on replacing the runflats. Also install a partition, it will make a huge difference!
To road noise
Old May 25, 2007 | 09:47 PM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Michelins changed my life....
Old May 25, 2007 | 09:50 PM
GS Ron's Avatar
GS Ron
Old May 25, 2007 | 09:52 PM
C5naples's Avatar
C5naples
If you do a search there are a lot of threads on insulating the back of the car. Many do the entire rear cargo area and also under the seats and the console area. Supposed to make a huge difference, the only time it bothers me is on the interstate.
