Any oil Consumption between changes?
Old Jun 7, 2007 | 11:21 PM
Firethorn55's Avatar
Firethorn55
I have an 01 with a build date of 08/00. I go through a quart about every 2K. I can live with it.
Old Jun 9, 2007 | 10:16 PM
Sorny's Avatar
Sorny
1/2 qt every 6000 miles or so. Most of which is caught in my catch-can.
Sorny
Old Jun 10, 2007 | 11:22 AM
fdxpilot's Avatar
fdxpilot
Originally Posted by Jet-Jock
And my thoughts on the recall/warranty, is it really worth having it completely torn down by the dealer service (not that there is anything wrong with them) to change rings? A qt every oil change is fine with me.
Oh and yes I'm one of those weird one's who likes to get at or about 3K rpm contributing to my problem. Sorry I like the acceleration and sound.
I don't believe it was a recall. It was a TSB, which is a bulletin to fix a known problem not affecting safety. As you are long out of warranty, it will cost you to have the engine re-ringed, so no, it's not worth it.
Old Jun 10, 2007 | 11:37 AM
Jet-Jock's Avatar
Jet-Jock
I'm still under GMPP for another two years plus. That would probably cover it. My point was, it's only about a quart why tear into the engine for just that?
Old Jun 10, 2007 | 11:39 AM
pointu's Avatar
pointu
From: sometimes the lights are shining on me, other times i can barely see minnesota
my 01 uses about a quart every 2500 or so-no big deal
Old Jun 15, 2007 | 09:06 AM
lockmart's Avatar
lockmart
So they re-designed the rings after May 01 right? Anyone have an idea on the earliest date where it started? May 00 etc? I'm looking at a 2000 and don't want to have this issue.
Old Jun 15, 2007 | 09:23 AM
GrandSportRob's Avatar
GrandSportRob
My 99 doesn't burn any oil..I stayed away from 01's when searching for a used C5 for that very reason..
Old Jun 15, 2007 | 09:51 AM
Cole's Avatar
Cole
Originally Posted by sdspeed
i have an '01 with 42k miles on it, not driven hard for a 6 sp. Still using Mobil 1. It seems to burn about 1 qt. every 5k miles. Car was built in 9/00.
Do I have a concern or not? any thoughts?
That is insignificant. Change the oil every 5K and stop worrying.
Old Jun 15, 2007 | 09:53 AM
sailohio's Avatar
sailohio
Don't worry-Be Happy!
Old Jun 15, 2007 | 10:51 AM
lockmart's Avatar
lockmart
I'll be happy if I buy this Corvette and don't have to check the oil all the time!! I'll be using it as my daily driver.
Old Jun 15, 2007 | 11:08 AM
1-BAD-C5's Avatar
1-BAD-C5
Go to a chevy dealership and get a the new design pcv valve it is made for motors that consume oil. and get a catch can so you dont keep recirculating that oil into the intake manifold. PCV is $6.88 and a decent catch is about $100 or so. And hopefully that should help your consumption problems,.. if not switch up to a thicker synthetic oil like amsoil. Something that wont find its way past the rings,.. if you are indeed having ring flutter. Good luck any questions just ask
Old Jun 15, 2007 | 11:47 AM
allred's Avatar
allred
According to everything I have read the new rings were not fitted to cars until very early production 2002 for LS6, and "a few weeks later" for the LS1. So unless your car was manufactured in 2002 (or later) it won't have the ring fix.
Here's a link to the low down on it all........
http://www.c5registry.com/2k2z06/page5.htm
Old Jun 15, 2007 | 12:33 PM
  #33
lockmart's Avatar
lockmart
Nice article, didn't mean to hijack the thread but it is related to the topic. For some reason you hear about 01's with the problem more than other years, so I thought perhaps there was a bad batch of the already previous design or something. I guess it isn't really an issue with regular driving. I'd like to accelerate fast and rev the engine now and then, but I can't see driving around steadily at high rpm's.
Old Jun 15, 2007 | 12:51 PM
  #34
georgec114's Avatar
georgec114
If you have a warranty, then get it fixed. It's not just the loss of oil but
the loss of performance and the buildup of carbon.
A lot of people had this problem and instead of "going through the
trouble" of getting it fixed, they just dumped oil in and then dumped
thousands of C5s off on other unsuspecting second owners.
I had mine done, (changed rings and pistons) and it cured the oil
consumption and piston slap. It took all of 3 days out of my Vette life
and the next owner had a pristine 2001.
GM picked up the tab and I had a great dealer do it.
Oh, and it was an A4 and driven gracefully and I burned a quart in
800 miles. Build date 08/04/2000.
GET IT FIXED!
Old Jun 15, 2007 | 01:07 PM
  #35
lockmart's Avatar
lockmart
Ouch, a quart in 800 miles....
Anyone have an idea what it would cost for an out of warranty car? Did they extend the warranty for this item by chance? I'm looking at an 00 with 28K miles.
Old Jun 15, 2007 | 01:34 PM
  #36
Flyskate's Avatar
Flyskate
I must be one of the lucky ones. I have a modded LS-1 motor(98) Cartek 2x heads cam, zo6 intake, etc. and burns 0 oil. I've never had to add any oil between oil changes, even after 6-8 runs at the track!
Old Jun 15, 2007 | 01:46 PM
  #37
SLPRC5's Avatar
SLPRC5
Do you happen to have the part number for the new pcv?
To Any oil Consumption between changes?
Old Jun 15, 2007 | 02:39 PM
  #38
WetteVette's Avatar
WetteVette
'97 here. Doesn't burn any oil at all.
Old Jun 15, 2007 | 03:31 PM
  #39
Luv2Run's Avatar
Luv2Run
St. Jude Donor '13
Originally Posted by zTrek
my '02 hasn't burned oil...
And I change oil based on GM recommendations (DIC) averages every 8-10k, 70% interstate miles
Don
Old Jun 15, 2007 | 04:21 PM
  #40
1-BAD-C5's Avatar
1-BAD-C5
12572717 part is actually $10.24 with tax the regular pcv valve is $6.88
Good luck!
