How low have you guys found it needs to be in order to trigger the low oil level display on the DIC? On my last oil change I purposely only put in 5 quarts, in order to see if the warning came on. I drove it like that for two days and the warning never came on, despite being 1.5 quarts low! (don't worry, I didn't drive it hard during this time so no damage would've been done)
It means the oil is low - when the oil life gets down to around 5% it will say change oil soon. Might want to check the oil level soon or just go ahead and change it.
Thanks, guys...thats what I figured, but just wanted to be certain. I was a little late about 11:40 when I got home last night and the message flashed, and was in no mood to look at it.
I was late heading to work this morning and forgot about it until about 30 minutes ago, but the message has not flashed all day, and I have left the office about 4 times now.
I was parked on a rather steep incline when I started the car last night. Maybe that had something to do with it...but in any case, I guess I am going to get dirty later.
Yep an incline can set the message off. Did you check your oil level ?
I have had mine come on when parked on an incline several times and I check my oil all the time as when in boost mine pushed some in the catch can and I just top off my baby and you should check to make sure all is ok
