Which would you do?
Old Jun 13, 2007 | 06:51 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Originally Posted by 1998whitecoupe-a4
Thanks to all, gears it is!
__________________
..................Click for
Old Jun 13, 2007 | 06:58 PM
Nick1's Avatar
Nick1
Like some of the above say, it depends on your long range plans. A significant gear change gives great low end acceleration improvement, so if you go to the track often or get on it a lot that's for you. On the other hand, simpler bolts ons may ease your thirst to experiment, give some improvement, and maintain good highway gas mileage.
I did it all with my '96 Camaro, and now not quick to mess with the rear again. You could also wind up with a rear end drone since there is a lot of "art" (and expense) to setting it up "right".
I'm enjoying my '04 C5 more as a touring vehicle and liking it more or less like it is. Have fun
Old Jun 13, 2007 | 07:02 PM
1998whitecoupe-a4's Avatar
1998whitecoupe-a4
aw man, why you making me think twice now
Old Jun 13, 2007 | 07:25 PM
M6 Vetter's Avatar
M6 Vetter
What ever you do, I don't think you will regret it. But you will feel more power with the gears
Old Jun 14, 2007 | 07:14 AM
Davko's Avatar
Davko
Somebody correct me if I'm wrong - You have 2.73 gears in your A4 right now. If you do a switch to 3.15 gears, you won't need to change the TC or reprogram the tune. You should still feel some significant difference for the street - which appears to be your goal. As an aside, you shouldn't affect your warrenty that way. No one can see your gears, but a tech can tell if the vehicle has been reprogramed. That can save you the added costs associated with going higher in gears, which you shouldn't need for the street anyway.
Old Jun 14, 2007 | 09:34 AM
LMB-Z's Avatar
LMB-Z
I have 3:15's in my A4. I love them. I still get good gas mileage, 28 on the highway. It has lots of low end power. I think you would be satisfied. Just my .02
Old Jun 14, 2007 | 01:40 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
I went with the CAI & cat back, then Long Tubes, kept it that way for years then went with 3.42's and a cam.
I'd do it that way again no regrets.
Good luck with your decision.
