A/C question
Old Jun 13, 2007 | 04:51 PM
RFS-Z06's Avatar
RFS-Z06
Default A/C question
Air is blowing cold, but is not blowing out of the vents very hard. Can feel it coming out in floorboard too. Any ideas
Old Jun 13, 2007 | 08:29 PM
JWB ZO6's Avatar
JWB ZO6
St. Jude Donor '06-'07
Sounds like one of the doors that control the direction of the flow is not working.
Old Jun 13, 2007 | 11:56 PM
my6thvette's Avatar
my6thvette
If it is coming mostly out the defroster vents, it is probably a vacuum problem. This usually occurs when a leaking battery eats up the nylon vacuum lines under or behind the battery.
Old Jun 14, 2007 | 12:58 AM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
Switch it to upper body fan only & recirculate, it's COLD for me!
Old Jun 14, 2007 | 11:13 AM
Vette Nutz's Avatar
Vette Nutz
You might want to check the coil out before you take the dash apart. They can get packed up with dirt, silt and gunk and cut down on the air flow.
Old Jun 18, 2007 | 02:39 PM
RFS-Z06's Avatar
RFS-Z06
Tanks for the help... Will check it out today..
To A/C question
