Steering Column locked up
Old Jul 2, 2007 | 08:47 PM
shelbycuda's Avatar
shelbycuda
2nd Gear
Default Steering Column locked up
The steering column in my 2000 locked up today ... anybody seen this before? The manual says it needs to be towed into the shop?
Old Jul 2, 2007 | 08:52 PM
WWK888's Avatar
WWK888
Hit the search feature, and knock yourself out. Yes it is a common problem, there have been several recalls but I would recommend getting the CLB (Column Lock Bypass kit).
Old Jul 2, 2007 | 08:55 PM
Bob CTS's Avatar
Bob CTS
Yes common, ready the sticky at the top on the column lock, do not take it to the dealer, do a search and buy the CLB (column lock bypass) and you will not have any more issues. Also you could shake the wheel sometimes this temporarily fixes it, but it will return like a nightmare.
Old Jul 2, 2007 | 08:59 PM
dezcapt51's Avatar
dezcapt51
Yep!!! the old column lock dog bites another victim. Try turning wheel hard from side to side if this doesn't work you might have to have it hauled. GM fixed this very common problem under warranty for us y2k guys. I know there is a CLB that you can have installed to fix this problem once and for all.
Old Jul 2, 2007 | 09:00 PM
lawZ's Avatar
lawZ
CLB is the only fix that works!
Old Jul 2, 2007 | 10:00 PM
vett79's Avatar
vett79
Is this problem in all C5 years?
Old Jul 2, 2007 | 10:25 PM
mmaynard's Avatar
mmaynard
Installed CLB tonight. Works great. Took a little over an hour but I was being cautious. Corvettes of Houston, about $50.
Old Jul 2, 2007 | 10:33 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Good and only real fix.
Took me a lot less time and I had a hard time with my big hands getting the connectors unplugged. You must have been being very cautious.
Old Jul 2, 2007 | 10:37 PM
stingray4me's Avatar
stingray4me
Did you buy it from a chevy dealer ? You may get it fixed for free call em & see.
Old Jul 2, 2007 | 10:56 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
DO NOT follow this advice. Dang, I am amazed that anyone would suggest this
Dealer (GM) solution IS NOT reliable, or desirable.
Get the CLB kit and have it installed (NOT by the dealer), or DIY.
Old Jul 2, 2007 | 11:02 PM
WWK888's Avatar
WWK888
Seriously this is not good advice. By letting the dealer perform the recall you open yourself up for faulty k harnesses and the reprograming of your computer to cut fuel. Many people have regretted going to the dealer and wished they had just installed the CLB from the start.
Old Jul 2, 2007 | 11:12 PM
Many, many threads about this topic. Search the forum and see if you can get the column unlocked using one of the methods discussed. Then go and buy a column lock bypass from one of the fine forum vendors, install it, and end your worries.
Old Jul 2, 2007 | 11:16 PM
alanhang's Avatar
alanhang
who is the best to buy it from??
Old Jul 2, 2007 | 11:21 PM
Cozmo's Avatar
Cozmo
http://www.corvettesofhouston.com/pr...3161f012aae4e3
Old Jul 3, 2007 | 01:07 AM
DeeGee's Avatar
DeeGee
CLB
Old Jul 3, 2007 | 05:19 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Do not bring your car to the dealer for the recall.
Install a Column Lock Bypass:
http://97vette.com/howto/columnlock/index.html
http://www.ls1howto.com/index.php?article=24
You can get from either of these vendors:
http://www.corvettesofhouston.com/pr...e9bf70207aef69
http://www.thunderracing.com/catalog...d=220&pcid=156
Old Jul 3, 2007 | 06:54 AM
M6 Vetter's Avatar
M6 Vetter
What the f***
To Steering Column locked up
Old Jul 3, 2007 | 07:56 AM
RedSoxFan's Avatar
RedSoxFan
You may also get it fu#*ed up for free. Don't do it.
Old Jul 3, 2007 | 08:21 AM
Black 'n Tan's Avatar
Black 'n Tan
St. Jude Donor '07
Take no chances, CLB from Corvettes of Houston, THE CURE! I have an '04, knowing GM, I'm sure I have the same potential problem. I'm not taking the chance!
John
Old Jul 3, 2007 | 11:22 AM
6pac's Avatar
6pac
I jumped the gun when I 1st got my car and let the chevy dealership do the recall. Shortly after the "security light" on my dash just turns on during hard left or right turns and stays on until I turn off the car.
I called the dealership and they wanted $100 to see if their work on the the column recall causes my security light to go off.
No Thanks.
