A4 Drivers-Do you use one foot or two?
Old Jul 4, 2007 | 10:42 AM
  #61
dndrsn's Avatar
dndrsn
One of you left-footers should go over to "Wikipedia" and "edit" this out.
Left-foot braking
Road use
This practice is not recommended while driving on public roads. [4][5][6]
Instead, drivers are advised to use the right foot for both acceleration and braking. The primary reason for this is that there is never any situation in a car with an automatic transmission where it is safe or necessary to apply both brake and throttle at the same time. Using one foot for both ensures that the driver can only operate one pedal.
Additionally, in emergency braking situations, it is common for the driver to extend both legs in a panic reaction. If the right foot is on the throttle, this will cause unwanted and potentially dangerous acceleration.
Most manufacturers of cars with automatic transmissions provide the car with a rest for the driver's left foot so the right foot may be used exclusively for throttle and braking.
Also, when the left foot is often used for depressing the clutch pedal this generally requires more force than operating the brake. A driver accustomed to applying this amount of force may unexpectedly slow down to an unsafe speed when attempting to use the left-foot braking technique.
Using the left foot for braking can also cause confusion when switching to or from a vehicle with a manual transmission because of the differing roles of the left foot. [7]
In addition, many modern vehicles use a "Drive By Wire" or Electronic throttle control system instead of the traditional mechanical throttle linkage. These systems have a safety interlock that prevents left foot braking. The car's ECU can detect when both pedals are pressed simultaneously and will immediately cut the engine power for safety reasons.
Old Jul 4, 2007 | 12:33 PM
  #62
M6 Vetter's Avatar
M6 Vetter
Right foot only here
Old Jul 4, 2007 | 02:49 PM
  #63
BATM4N's Avatar
BATM4N
Using right foot is the correct and safest way known to man
Old Jul 4, 2007 | 03:26 PM
  #64
dw99vette's Avatar
dw99vette
From: 15 miles south from the Raisin Capitol of the World Caifornia
The only time I used both feet they were both smashing the brake pedal to the floor because some dumb a$$ pulled out in front of me on the highway.
Old Jul 4, 2007 | 04:27 PM
  #65
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
One foot.
Old Jul 4, 2007 | 05:19 PM
  #66
Johnny_B_Good's Avatar
Johnny_B_Good
St. Jude Donor '05 thru '26
Two feet for me.
Old Jul 4, 2007 | 05:39 PM
  #67
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Usually one foot. I use two when there is a possible contest at the light's change, although that is a rare occurrence.
Old Jul 4, 2007 | 06:18 PM
  #68
Bracketman's Avatar
Bracketman
Depends on the conditions. If I'm just cruising or in the city, I use right only. Twisty mountain ranges or passing porches on those mountain ranges, I use both.
Old Jul 4, 2007 | 07:56 PM
  #69
1FASTVERT's Avatar
1FASTVERT
St. Jude Donor '12
Right foot only,left is on the dead pedal.
Old Jul 4, 2007 | 08:40 PM
  #70
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Originally Posted by Vega$Vette
Right foot only. Left is on the dead Pedal
Old Jul 4, 2007 | 08:46 PM
  #71
FactoryRaceCar's Avatar
FactoryRaceCar
I dont have an A4 but I own a few automatic transmission vehicles and ALWAYS use the right foot for acceleration and braking.
Old Jul 4, 2007 | 08:54 PM
  #72
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
I dont have an A4 but I own a few automatic transmission vehicles and ALWAYS use the right foot for acceleration and the left foot for braking.
Old Jul 4, 2007 | 08:55 PM
  #73
drews60's Avatar
drews60
You can drive with 6 feet as far as I care. Just quit riding the brakes, making the brake lights come on. It drives me batty. Not a long drive!
Old Jul 4, 2007 | 09:02 PM
  #74
Quick Silver Z
I hold my left foot over the brake pedal in anticipation of it's use, never resting on it. In panic mode I instinctively use both feet on the brake pedal...
Old Jul 4, 2007 | 09:05 PM
  #75
Z06PDX's Avatar
Z06PDX
Originally Posted by Mr. Couture
Right foot only. You're more likey to get in a car crash if you use both feet
sorry...thats about the dumbest thing i have read here. 40 years 2 feet...no accidents
Old Jul 4, 2007 | 10:42 PM
  #76
zTrek's Avatar
zTrek
Left-foot braking
Road use
Sorry, but not much of the above applies to those of us that have been left footing for many years if not decades. The key to proper left footing is not to be depressing both pedals at the same time. It is to reduce the reaction time when covering the brake in situations that warrant. Similar to what good motorcycle riders are taught to do in mitigating situations where someone might unexpectedly pull out in front of you. There is a huge advantage in reducing the time it takes to move the right foot from one pedal to another in situations that require quick footwork. For the record, I have been left footing for over 30 years and have found the Corvette no different to drive in that manner than any other auto I have driven...because I'm never attempting to ride the brake while on the accelerator.
Old Jul 5, 2007 | 01:01 AM
  #77
HIRISC's Avatar
HIRISC
St. Jude Donor '06
When I had my A4 C5, I always used two feet (aka left foot braking).. this was born under performance driving conditions and ended up staying with me during normal pace street driving.
I drive my X5 the same way.
I guess my left foot doesn't want to be left out.
