Clearcoat removal from wheels
Old Jul 8, 2007 | 01:58 PM
2fast4sanity's Avatar
2fast4sanity
Default Clearcoat removal from wheels
I was just wondering if there is an effective way to remove the clear from polished Y2k wheels without removing the tires. How well do they hold up like this? I want to use mine as training wheels to see if I will be able to maintain them before buying something like ccw's or hre's.
Old Jul 8, 2007 | 03:43 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I did a quick search in the Wheels & Tires section in the archives and found a couple of early threads on this topic. It seems that you can purchase a commercial paint stripper that is identified as being able to strip clear coats - it's a spray on product and is available in auto paint establishments. No product was named specifically, but the process was to start with a clean and dry wheel - spray on the stripper and then powerwash the wheels.
http://forums.corvetteforum.com/show...coat+on+wheels
Old Jul 8, 2007 | 03:45 PM
Allzwell's Avatar
Allzwell
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
I can't imagine that there is any way to do it with the tires mounted. Anything that will strip clear coat will eat your tires.
Old Jul 8, 2007 | 03:53 PM
hotwheels57's Avatar
hotwheels57
Aircraft paint stripper is what I've used to remove the clear coat effectively. It's nasty stuff so use according to the manufacturers warnings on the label (well ventilated area w/ hand/eye protection).
You can find it at automotive paint supply sources. I've used it with the tires removed. I'd think there might be a good potential for rubber degradation if the tires/stems were left mounted.
The other manner to remove the coating might be with a professionally applied soda blasting which is used to remove paint, rust, etc from classic car bodies. It'll remove the finish and shouldn't damage the tires like a caustic acid. The finish remaining might require additional steps in polishing though.
Old Jul 8, 2007 | 06:41 PM
66ratpower's Avatar
66ratpower
I have stripped a set of thin spokes. You will spend countless hours hand sanding with various grits of sandpaper before you are happy. It is easy to do with the tires on. Stripper will not harm the rubber as long as you wash the wheels and tires . As a sidenote....I'd never do it again. The sanding takes huge amounts of time and effort. My 2 cents.
Old Jul 8, 2007 | 08:15 PM
Quicksilver Z06's Avatar
Quicksilver Z06
Also, once you start, there is no turning back! I thought it would be an afternoon project, was I wrong! Purchased a set of Motorsport rims that night! A couple afternoons with lots of sanding, and I'm still not happy.
Be careful if you use a pressure washer as the stripper goes everywhere, and will burn holes in your skin!
Good luck!
Old Jul 8, 2007 | 10:16 PM
I agree - I'd probably remove the tires to prevent any potential damage to the rubber.
Old Jul 8, 2007 | 10:41 PM
C5naples's Avatar
C5naples
I stripped mine. With a brush on paint stripper from Home Depot.I left the tires on. Did not use a pressure cleaner. I also cleaned of the residue with MEK. I did not sand like one of the posts said earlier, I buffed the wheels with a spiral sewn buffing wheel on a cordless drill and some mothers. Here are the results;
Old Jul 8, 2007 | 10:54 PM
jrprich's Avatar
jrprich
[QUOTE=C5naples;1560990691]I stripped mine. With a brush on paint stripper from Home Depot.I left the tires on. Did not use a pressure cleaner. QUOTE]
How long did that process take you ?
Those are some GREAT looking wheels !!
Old Jul 8, 2007 | 10:58 PM
C5naples's Avatar
C5naples
[QUOTE=jrprich;1560990902]
About 4 hours per wheel. I am not lying to you it takes a lot of patience!
Old Jul 9, 2007 | 12:35 AM
BrianWe's Avatar
BrianWe
[QUOTE=C5naples;1560990942]
That looks awsome. I may have to do that as mine are starting to look pretty bad on the insides.
Old Jul 9, 2007 | 04:12 AM
edensknight's Avatar
edensknight
Yes, it is best to remove the tires and valve stems from the wheels first, in an effort to prevent possible damage to these sensitive, often rubber and plastic wheel features, because of the caustic, and, degrading nature of the product ("Paint Remover"). FYI: Jasco Premium Paint and Epoxy Remover has been a common clear coat remover used in the aftermarket wheel industry for many years, to remove the clear coat found on many custom wheels from the originating wheel factory. This product is available at the Home Depot and Ace Hardware for just over $50 for a one gallon can.
Patience is paramount in this specific process, AND, do be sure to wear gloves, eye protection, etc. Once the clear coat is completely stripped, you will then be able to polish your wheel to a far more appealing luster with any polishing equipment of your choice (Eastwoods, Mothers Powerball, Professional Wheel Polishing, etc.). Finally, do keep in mind that when you remove the protective clear coat, the exposed surface will be more vulnerable to water stains, and, discoloration from the road and the general environment. Thus, polishing the wheels regularly will assist in maintaining a shiny surface. BTW: Naps, you did an awesome job, good buddy!
Old Jul 9, 2007 | 06:05 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by edensknight
ek
Old Jul 9, 2007 | 11:13 AM
rcmigpilot's Avatar
rcmigpilot
Can the wheel be recleared? The ones on my 04 are kind of milky and I think they can me much better, but don't want to have to pull then off every month to do a good polish inside and out.
Old Jul 9, 2007 | 12:11 PM
robert123's Avatar
robert123
I had aluminum wheels with the tires on them and I stripped and polished them with no problems.
To Clearcoat removal from wheels
