Traction Control Issue
Old Jul 13, 2007 | 09:15 AM
Tbas99C5's Avatar
Tbas99C5
Default Traction Control Issue
I just had new wheels and tires put on yesterday, and as I'm driving away from the shop, I go around a turn (a jughandle) and my traction control comes on. Every time I turn the wheel it activates now. Any ideas on what the shop could have done to screw the TCS up? I have to drive with it off now just to go anywhere.
Old Jul 13, 2007 | 09:18 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
What are your tire sizes?
Old Jul 13, 2007 | 09:23 AM
Tbas99C5's Avatar
Tbas99C5
245/40/18 and 275/30/19
Old Jul 13, 2007 | 09:43 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Well, there is your problem....your front tires are slightly taller than the rears.
Traction control works by comparing front/rear wheel speeds. Any time you alter tire heights, you alter the speed the wheel sensor reads.
On a stock C5, the rear tires are about 1" taller than the fronts. Not just wheel size, but meaning the total tire height (25.6" front, 26.7" rear). Reducing that 1" height difference will make traction control more sensitive, and when you get to the point of front tires being taller than rears, you will find traction control coming on in just normal driving (like you're experiencing).
You now have front tires that are 25.7" tall, and rears that are 25.6" tall, and that is the problem.
I would suggest looking into a 275/35/19 or 285/35/19 size rear tire to cure this...otherwise, your only option is to continue driving with traction control off.
Old Jul 13, 2007 | 10:32 AM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
I'm sure Y2Kvert4me isn't recommending you drive with the T/C off and I don't either. This car will get out of control in a hurry without it. I'm hoping the tire store recommended the tires to you. If that is the case you should be able to go back to them and explain that they are creating an unsafe condition. I'm sure they will offer a better tire combo. Either a taller rear or a shorter front tire. For best results make sure both front and rear are as close to original diameter as possible but be sure to maintain the 1" hieght advantage on the rear.
Good Luck.
Old Jul 13, 2007 | 11:07 AM
Tbas99C5's Avatar
Tbas99C5
Guys,
I agree, driving with the Traction Control off is not going to work as a solution. Because I'm ignorant about tire sizes (which got me into this mess in the first place), can you guys let me know a couple things?
- What size tires will definitively fix this in the rear? 35?
- Right now my rear wheel wells look terrible....empty. Will a 35 help fill them up?
- The vendor said he won't take them back because I drove on them. Is that reasonable? He recommended them and said that's what his manufacturers recommend.
Thanks for the help.
Old Jul 13, 2007 | 11:50 AM
mschamberger's Avatar
mschamberger
That was very informative response. Members like you keep me hanging out here.
(uh, I really don't have anything to add to the thread, I just like to hear myself type. )
Old Jul 13, 2007 | 01:07 PM
Tony Kataro's Avatar
Tony Kataro
DITTO!
Old Jul 13, 2007 | 01:10 PM
DeeGee's Avatar
DeeGee
Now I'm on shakey ground here but.........
I seem to remember that the TCS has some sort of calibration.
When I had my EBCM replaced and also when I had the new tires fitted I remember that the AH seemed particularly sensitive. It would pitch in when I made even the gentlest corrections and throw a caption. After a few manoeuvers it settled down.
All that said, the system senses wheel position in order to work. If they've screwed the basic alignment (for example got the steering wheel out of alignment) or damaged the sensors you may have a problem.
I'd give it a few days and see how you go. If its still bad take it back because they've caused the problem.
Any codes?
Old Jul 13, 2007 | 01:18 PM
Oldvetter's Avatar
Oldvetter
All that said, the system senses wheel position in order to work. If they've screwed the basic alignment or damaged the sensors you may have a problem.
Active handling needs the car to go straight for a while to calibrate, if you turn as soon as you start up, it will say "active handling warming up".
This has nothing to do with his problem.
Although stock tires have 1 inch difference, the systems will work will 1/2 inch difference. If he recommended these sizes, he should fix it. I doubt that his book recommended these sizes, he probably just choose what he had in stock close. You could ask to see his book?
Old Jul 13, 2007 | 01:24 PM
DeeGee's Avatar
DeeGee
I appreciate that. I've had the "AH Grumpy Morning Message"
My point was that the system needs to recalibrate after fitting the new wheel sizes (18/19 rather than 17/18s)
Either they've screwed up the basics or the computer is just "getting its bearings". If they got the steering wheel misaligned or damaged the sensors it will throw a caption
My experience was it took a couple of trips before my AH settled down. And I fitted Michelins of the correct size.
Old Jul 13, 2007 | 02:54 PM
Tbas99C5's Avatar
Tbas99C5
I tend to agree that if they were recommended that they should be taken back. I also agree that he's trying to sell what he has. I'm really frustrated by this.
Anyone know if the 35 series will fill up the wheel well better?
Old Jul 14, 2007 | 01:31 PM
VQMotoring.com's Avatar
VQMotoring.com
Mike,
I never try to sell just what i have in stock. I always had both the 30 and 35 series tire in stock. If a customer ask me what will look better, i will state my opinion and my opinion was the one you ended up going with. On all 3 of my customized cars my traction control system does not work properly either. I belive it should be because if tire hight also. I think they look great buti dont use my traction control anyways. For me, when modding a car there are always things i have to sacrifice to get pther things i want to have. If i want to have a fast car, i have to sacrifice the car being in the shop all the time or broken down because i have boost leak. But in the end this is my true passion.
anyhow, as you know we are here to help so please call us on monday so at least we can try our best to help you out.
Hope you all have a great weekend.
Thanks,
vqmotoring.com
(877)-877-9420
Old Jul 14, 2007 | 01:47 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
If you recommended the 30's in the rear and DIDN'T mention that the AH might not work and that it doesn't work in your cars, then I think you should take them back.
jeff
Old Jul 14, 2007 | 02:52 PM
M6 Vetter's Avatar
M6 Vetter
IMO you should have told him that if he went with the 30' he
might experience AH/TC problems, like you are....
Even though you're ok with it,, he might not be.
Old Jul 14, 2007 | 03:32 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I don't know what year your vette is ?
C5's came with 17 and 18's not 18 and 19's.
The new C6's come with 18 and 19's.
Hopefully you paid by credit card, if so dispute charges.
Old Jul 16, 2007 | 04:51 PM
WFD088's Avatar
WFD088
3rd Gear
All other comments aside, Y2Kvert4me is correct, the issue is not AC, but TC and front to rear height ratio. I bought my '97 last year and all seemed fine after a test drive. As I left the dealer and sped up on an x-way ramp, same conditions you describe. Returning to dealer, I went directly to Service. The Tech came out, took one look at the custom 18" rims all around and tire size and said, "Wrong tire sizes"
Sure enough, replaced all 4 with new 18's but matching the original height, and all has been fine ever since!
BTW, hats off to Bob McDorman Chevy in Ohio. They diagnosed the problem in minutes, and offered a settlement AFTER the sale to correct the problem!
To Traction Control Issue
Old Aug 25, 2007 | 02:15 PM
Vette_Fan's Avatar
Vette_Fan
Originally Posted by VQMotoring.com
Mike,
Thanks,
vqmotoring.com
(877)-877-9420
Dude, you're one fast talker... and a BAD sales person/business man. What you do in your life, is your choice. You don't go around giving "YOUR PERSONAL OPINIONS/PREFERENCES" to others, when they ask you for advice .. Instead - - You are supposed to give them "FACTS", and tell them the consequences..............and then let them decide. What looks good, or whatever sacrifices you enjoy making, others may NOT want the same . They look up to you as a "Professional". Act like one...
Before you reply my comments, Read this thread and fix it, if you're really a MAN !!!! http://forums.corvetteforum.com/show....php?t=1795263
Old Aug 25, 2007 | 03:37 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Not good ! ! Hope you get it taken care of ! !
Old Aug 25, 2007 | 03:43 PM
VinnyT's Avatar
VinnyT
I never heard of 40's up front and 30's in the rear. Regardless of the wheel size, that just seems odd. I would have at least matched the aspect ratio. 30's or 35's all the way around.
