Tire pressure sensor problem
Old Jul 23, 2007 | 12:08 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
Default Tire pressure sensor problem
After just over 3 years I have finally had the misfortune of getting a nail in one of my tires. My question is this. The DIC reads that the Left Rear is flat. That would lead me to believe that it is the drivers side rear. However, it is the passenger rear that is flat. My question is this, are the sensors programmed to know where they are supposed to be. I had my tires replaced last year and am wondering if they switched what side the rims are on. Thanks in advance
Old Jul 23, 2007 | 12:14 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
The sensors are programmed to know which position they are in. They just need to be re-trained...very easy and only takes a couple of minutes.
jeff
Old Jul 23, 2007 | 12:34 PM
GrayC5's Avatar
GrayC5
jeff
See following C5 Tech Tip:
Resetting Tire Pressure Monitors
Old Jul 23, 2007 | 12:43 PM
csexton's Avatar
csexton
jeff
and you will be good to go
Chuck
Old Jul 23, 2007 | 04:29 PM
DeeGee's Avatar
DeeGee
One of two problems.
Either they put the tires on the wrong rims and put them back on the wrong side. That means the rims/sensors are now at the wrong corner
Or ................
they put the tires on the correct rim and put the wheels on the wrong side. That would be bad as the tires are directional. If thats the case, providing the tires are rotating in the correct direction just retrain the sensors.
Old Jul 23, 2007 | 05:15 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
This is great but what about changing a battery in the TPS
Can it really be done? Need and want to know!
Thanks,matt
Old Jul 23, 2007 | 05:47 PM
rws.1's Avatar
rws.1
There is mixed success reported on changing the batteries...
They are potted batteries meaning that they are encased in a thermoset resin like epoxy.
You need to remove the resin with a dremel tool, de-solder the old battery, solder in the new one and re-pot it.....
Old Jul 23, 2007 | 05:54 PM
frodo84's Avatar
frodo84
Uneducated autodidact
this same exact post is in the tech section TWO times....I posted to one of them...
Old Jul 23, 2007 | 05:56 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
At the expense of installation I would suggest replacing the sensors with new ones from gene at gmpartshouse.com
Old Jul 23, 2007 | 06:09 PM
my6thvette's Avatar
my6thvette
Thanks,matt
http://forums.corvetteforum.com/show...lace=batteries
Old Jul 24, 2007 | 06:57 AM
madmatt9471
This'll be a big FAT NEGATIVE for me!
It'll be a new sensor insted! Screw the battery - Opppps!
Thanks,Matt
Old Jul 24, 2007 | 07:11 AM
trussme's Avatar
trussme
Thanks,Matt[/QUOTE]
...."don't you think you should kiss the battery first?"...
To Tire pressure sensor problem
