Leaking into heater box.
Old Jul 25, 2007 | 01:43 PM
Smooth72's Avatar
Smooth72
Default Leaking into heater box.
I have a friend that has an 02 water leaking into the heater box then into the floor. Has anyone had this problem and how did you solve it?
Old Jul 25, 2007 | 01:46 PM
SSWEET's Avatar
SSWEET
Do a search using water in passenger side footwell or try a/c drain tube...
Old Jul 25, 2007 | 01:59 PM
DeeGee's Avatar
DeeGee
Are you sure its not a blocked "udder"
Old Jul 25, 2007 | 02:26 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
Just water or anti frezze? Heater Core if its antifrezze
Old Jul 25, 2007 | 02:36 PM
csexton's Avatar
csexton
This may help
http://forums.corvetteforum.com/show....php?t=1246715
Chuck
Old Jul 25, 2007 | 03:04 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Originally Posted by csexton
the most common cause is condensation from the AC unit that can not drain due to a blocked udder...
Old Jul 26, 2007 | 01:45 PM
Smooth72's Avatar
Smooth72
Thanks for all the help
Old Jul 26, 2007 | 07:24 PM
Phanni's Avatar
Phanni
Blocked udder most likely.
Clear it ASAP.
Lift car, look for tube from air conditioner evaporator, clear debry from tube, enjoy the car...
It'll drip directly onto/into the Body Control Module (body computer $1000 +-) if not fixed.
To Leaking into heater box.
