Magnesium Wheel Weights
Old Jul 27, 2007 | 04:30 PM
SpedRacr93's Avatar
SpedRacr93
Default Magnesium Wheel Weights
I am about to put 18 x 9.5 C5 Magnesiums on all 4 corners of my 89 because I am tired of having different sizes on front and back and can't rotate.
Can anybody tell me if it is necessary to put ugly stick on weights on the outside of the rim like the factory insisted on applying? Can't I just put them on the inside of the rim like aluminum wheels????
Thanks!
Old Jul 27, 2007 | 05:36 PM
rpm462's Avatar
rpm462
I have the magnesium wheels and have the strip weights on the inside of mine.
Old Jul 27, 2007 | 05:39 PM
Zozzie's Avatar
Zozzie
Me too. I had one balanced just yesterday and the fella stuck them all (of course) on the inside.
None of my other three wheels have anything on the outside.
Old Jul 27, 2007 | 05:59 PM
SpedRacr93's Avatar
SpedRacr93
Thanks!
Every wheel I ever saw from Chevrolet had them on the outside of the spokes. Always thought that was stupid, but thought surely they did it for a reason.... Guess Not!
Thanks again.
Old Jul 27, 2007 | 06:00 PM
hotwheels57's Avatar
hotwheels57
Yes, it's possible...the caveat is they may not be as secure if the double sided tape fails and they may not provide as accurate of balance as those crimped on the outside edge. This came from DISCOUNT TIRE when I had my new wheels done on a new truck.
Old Jul 27, 2007 | 06:22 PM
Zozzie's Avatar
Zozzie
If someone crimped wheelweights onto the edge of MY magnesium rims I'd whack 'em up the side o' the head with a 2x4. I'm very new to Corvettes and mag rims but I very much doubt that they're meant to have clip-on weights marking their coating and gouging their soft metal.
I just had a mag rim replaced yesterday as a dealership tire-changing person took a chunk right out of one of my wheels while inserting new TP sensors. And yes they bought me a new wheel.
The tire tech (I would not allow the job to be done at the dealership and risk another rim) lovingly stuck weights to the rim's inside.
Old Jul 27, 2007 | 06:29 PM
hotwheels57
I doubt that any car enthusiast likes the looks of wheel weights on the outside, but that's the manner in which 99% of manufacturers ship their vehicles from the factory.
Whether it's cheaper, faster or whatever, that's the way it's done. It might be the manufacturer is more concerned about function that aesthetics.
My Z16 still has the oem wheel weights on the outside of the polished forged wheels. Removing them now would leave the impressions in the clear coat anyway.
Old Jul 27, 2007 | 07:22 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Yep, on the inside is fine for 18" on all 4.
Tested to 160+ road racing as well without issue for 2 days
Old Jul 28, 2007 | 12:06 AM
SpedRacr93's Avatar
SpedRacr93
hotwheels - sorry for the confusion. I meant they have small weights that are about half the width of regular stick on weights that the factory put on the outside of the spoke... Its hard to describe if you haven't seen them. They're still flat, facing up towards the center lugs, but they're on the "pretty" side of the spokes instead of on the inside. These wheels don't have the rim guard ridge like most factory wheels do.
All Throttle - You've got yours mounted just like I was planning on doing, just wanted to check before I had it done.
Thanks guys.
Old Aug 8, 2007 | 03:32 PM
Dave1998's Avatar
Dave1998
Default Who has removed weights from Magnesium Wheels
When replacing tires, has any one removed the exterior factory weights? if yes, how do you do it ?
Dave
Old Aug 8, 2007 | 03:45 PM
Vampyre's Avatar
Vampyre
I have mags and never had weights on the outside..
Old Aug 8, 2007 | 04:00 PM
Dave1998's Avatar
Dave1998
Not the answer I was looking for
Old Aug 8, 2007 | 04:27 PM
Vampyre's Avatar
Vampyre
Are you saying you have exterior factory weights on your car?
I have never seen that. Are they held on with double sided tape?
Old Aug 8, 2007 | 05:25 PM
Cruise-In V Veteran
NCM Ambassador
This should help........OEM from our 2000 when new.
Double sided tape, same you see in my pics above except like said above.....on the pretty side of the spokes
Old Aug 8, 2007 | 05:29 PM
Dave1998's Avatar
Dave1998
Yes, here is another pic.
I want to remove these before mounting new tires
Old Aug 8, 2007 | 07:07 PM
Cruise-In V Veteran
NCM Ambassador
Best to use fishing wire and rubbing alcohol on a course rag to get the sticky stuff left.
Once you do a few, you can also use an xacto knife without chipping the paint.
I have done enough now I can use a box cutter
Just take your time and work the weights back and forth with your fingers as you break the adhesive say 1/2 way
Old Aug 8, 2007 | 07:59 PM
Dave1998's Avatar
Dave1998
Do you think there would be a benefit to letting the wheels sit in the sun all day to soften the glue or to use a hair dryer to heat the weights?
To Magnesium Wheel Weights
Old Aug 9, 2007 | 09:45 AM
Cruise-In V Veteran
NCM Ambassador
Sun will help, hair dryer better cause thats what you also use to get body side molding and emblems off
You are on the right track, good luck
Old Aug 9, 2007 | 12:39 PM
SavPrato's Avatar
SavPrato
Old Aug 9, 2007 | 01:41 PM
Yes, you should be able to have the weights put to the inside of the spokes.
