I use the parking brake on every vehicle I drive. It is the correct way to park. Now, the brake in the vette doesn't always hold, but that is why it is in R when I park it in addition to the parking brake.
If for no other reason, you should engage the parking brake 2 or 3 times a month to keep the cable from corroding tight in the cable housing from non-use. If it does, and at some later time you definitely need to use the p-brake, it willl come on but won't release, which could cause you a wee bit of distress and $$.
Use the ER brake only on an uneven (steep) place. Why? To relieve the pressure being put on the tranny. So, I pull the brake 1st, and then put it in P.
From: Assault is a behavior, not a device! Cypress TX
St. Jude Donor '11
Nope. Living on the Texas gulf coast you don't park on many hills. Even when on road trips...putting the transmission in "park" is all I have ever used in the past.
I use it at all times in all my vehicles. If you knew how small the Park latch was inside the transmission you would too. Holding a 3000# + car with a 1/4" X 1/4" X 1/8" piece of metal is spooky! Also, if you ever get bumped in a parking lot, besides the body damage you could be looking at a transmission teardown.
