A4 people, do you use E-brake
Old Aug 1, 2007 | 01:24 PM
  #61
Toms2001PewterC5's Avatar
Toms2001PewterC5
Rarely use it and because of that am skeptical of if it might get stuck in the on position from lack of use and corosion of the cable.
Old Aug 1, 2007 | 01:44 PM
  #62
peebee_c5's Avatar
peebee_c5
Interesting tip from my HPDE instructor:
Don't set the e-brake when stopped with hot rotors or you can melt some pad onto your rotors and you'll end up with pulsing brakes. For the same reason, try not to even use your regular brakes on hot rotors when at a complete stop.
I used to always set the e-brake. Stopped setting it after getting that advice just to break the habit of setting it.
Old Aug 1, 2007 | 02:04 PM
  #63
Zoomfast's Avatar
Zoomfast
Always.
Old Aug 1, 2007 | 02:06 PM
  #64
uk_vette's Avatar
uk_vette
Originally Posted by elctroman
i dont unless im on a steep hill
Putting into "park" locates a steel pin into the transmission.
Old Aug 1, 2007 | 02:23 PM
  #65
UKXPAT's Avatar
UKXPAT
I always use it every time I'm in the car. Habit from owning a manual.
Old Aug 1, 2007 | 02:47 PM
  #66
v.vet's Z06's Avatar
v.vet's Z06
Nope
Old Aug 1, 2007 | 02:51 PM
  #67
pimpjames's Avatar
pimpjames
Only when I think its going to get towed. Always do in the Camaro though since its a manual.
Old Aug 1, 2007 | 03:00 PM
  #68
BlackBeast 1997's Avatar
BlackBeast 1997
I always use it on any hill, but on a flat surface i do not. When i had my 85 with a richmond 6 spd i always used it on a manual, not so much on an auto. When this tranny goes i intend on putting a 6 spd in this as well then im sure i'll be using it more than.
Sometimes it's just a reflex to put it up.
Old Aug 1, 2007 | 03:13 PM
  #69
Bowhunter2001's Avatar
Bowhunter2001
Only on a steep incline.
Old Aug 1, 2007 | 04:51 PM
  #70
tonio76's Avatar
tonio76
Sometimes
Old Aug 1, 2007 | 05:14 PM
  #71
Zozzie's Avatar
Zozzie
Originally Posted by Mike McCoy
I use it at all times in all my vehicles. If you knew how small the Park latch was inside the transmission you would too. Holding a 3000# + car with a 1/4" X 1/4" X 1/8" piece of metal is spooky! Also, if you ever get bumped in a parking lot, besides the body damage you could be looking at a transmission teardown.
Precisely. When I was a GM mechanic (33 years ago!) I used to overhaul auto trannies. There isn't much metal holding the car in one place. Like you say - a nudge could wreck a tranny. I always use it if others could bump me or I'm on any kind of a grade. I don't use it in my garage. It just makes mechanical sense to me but then I don't remember any parking pawls failing either.
Old Aug 1, 2007 | 06:08 PM
  #72
Storm Cloud's Avatar
Storm Cloud
I agree, I always set the parking brake no matter what, and I am a automatic. I would much rather replace the brake pads more often then the part that holds the car back within the transmission. It's double coverage for when my beast is asleep. I don't like sleepwalking
Old Aug 1, 2007 | 07:25 PM
  #73
Bounty Hunter 6's Avatar
Bounty Hunter 6
Originally Posted by VinnyT
Always do. Habit.
I don't in any other automatic car, but for some reason I always do in the Vette. Sports car habit transfer. On a hill, definitely. Maybe it's because I went through all of the butt pain to fix the e-brake and now I like to use it!!
Old Aug 1, 2007 | 08:20 PM
  #74
fitterin's Avatar
fitterin
Always, just in case.
Old Aug 1, 2007 | 08:24 PM
  #75
C-5 Mike's Avatar
C-5 Mike
Me too.
Old Aug 1, 2007 | 08:30 PM
  #76
BobJ's Avatar
BobJ
Never.....no hills in PHX to park on.
Old Aug 1, 2007 | 09:15 PM
  #77
Big-Red's Avatar
Big-Red
St. Jude Donor '06-'07-'08-'09-'10,'13-'14
I use it as a matter of habit!!
To A4 people, do you use E-brake
Old Aug 1, 2007 | 09:20 PM
  #78
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Never
Old Aug 2, 2007 | 12:37 AM
  #79
Showdown's Avatar
Showdown
Originally Posted by Sethmo99
Forgot I had one til now, thanks!
Old Aug 2, 2007 | 12:43 AM
  #80
PierEagle's Avatar
PierEagle
So, what do ya do? Keep rolling or get against the other guy's bumper and let him/her hold you back?
