Replacement Battery
Old Aug 10, 2007 | 11:30 PM
moserbe's Avatar
moserbe
Originally Posted by MiamiCowboy
If the original battery in the car lasted 7 years then that is what I would replace with. I have not seen any testimonials on this forum that indicates any replacement batteries have come close to lasting 7 years.
If the original lasted 7 long years why wouldn't you replace it with the same battery????????????
Old Aug 11, 2007 | 12:37 AM
Junkman2008's Avatar
Junkman2008
I bought a yellow top and it died within 2 years, but it could have been because I left something plugged into the cigarette lighter all the time. Auto Zone gave me a new one after they tried the charge thing. One thing I don't remember though and that's the $150 price tag. I've got a red top in my Mean O' Camino and it always starts. I think I paid around $70 bucks for both (each).
Old Aug 11, 2007 | 03:26 AM
DeeGee's Avatar
DeeGee
Looks like you had most of the advice
I've had Red Tops and a Yellow Top for years now. I did kill one Red Top but it did sit on a boat with the Vert draining the life out of it for 2 months.
A coule of things I would say:
Red Tops wont leak
Old AC Delcos certainly do leak
If you look after a Red Top (battery tender) it'll give you years of life.
Take a look at this poll and make you own mind up
http://forums.corvetteforum.com/show....php?t=1469503
Of the sample so far
Red Top shows about 18% failure rate and AC Delco about 41%
Old Aug 11, 2007 | 07:09 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
I had to put a wally world in mine a while back and want to change it before it has problems,
At Autozone the have the red top for$130.00 and the Yellow for $180.00.Now I see PeterPan says he will get the yellow next time, I was about to pick up the red but now Iam not sure?????
Old Aug 11, 2007 | 08:02 AM
Tom/99's Avatar
Tom/99
I've had good luck with Delco batteries. I can't see going to another brand. You got seven years out of your origional battery, that should say something about Delco batteries.
Old Aug 11, 2007 | 01:55 PM
waterzap's Avatar
waterzap
Car is yellow...match the battery......
Old Aug 11, 2007 | 02:33 PM
Dave68's Avatar
Dave68
Red Tops wont leak
Keep in mind that AC Delco batteries made within the past 3 years are of a new design. Special attention was paid to strengthening the terminal post areas and the overall case structure is much stronger than the 97-00 design.
This is why you really can't use the poll as a guide to which battery you should choose. The AC Delco Professional batteries, while not AGP (which is prone to premature death if not kept well-charged), carry a 50 month free-replacement warranty - best in the battery industry. I know I keep repeating this, but I ust want to spread the word that the newer AC Delco batteries are nothing like the old lead-acids that had leaked in 97-00.
Old Aug 11, 2007 | 03:18 PM
The Wanderer's Avatar
The Wanderer
The original poll was interesting but flawed in the asking of the questions. The question should have been for example:
My Delco failed while under warranty
My Red Top failed under warranty
and so forth.
My original Delco failed after 3 years of hot desert temperature in New Mexico and one winter in Colorado Springs.
The real question is what battery doesn't fail while still under warranty. You spend the $$$$'s so you won't be stranded.
Old Nov 12, 2007 | 05:33 PM
EGbeater's Avatar
EGbeater
Not sure if the info I just got from my local Chevy dealer is accurate or not, but I was just told over the phone that the warranty on a Delco battery is a free replacement for "18-24 months," whatever the heck that means, and that after that, it's pro-rated.
Which, to me, is another way of Delco saying they don't really expect the battery to consistently last much longer than 18-24 months.
On the plus side, the stealership parts guy did say that any Chevy dealer would honor the warranty w/ the original receipt.
Old Nov 12, 2007 | 06:58 PM
Bills03Coupe's Avatar
Bills03Coupe
Originally Posted by Bills03Coupe
Exide orbital in my Coupe for over two years, performs flawlessly!
Well it wasn't two years, because on 10-16-2007, my Exide Orbital failed, which was EXACTLY two years to the day after installing it! I did received a free replacement, but this time I will use a float charger to maintain a full charge. That's what I didn't do the first time!
Old Nov 12, 2007 | 08:01 PM
Oldvetter's Avatar
Oldvetter
Exide Orbital (sold at NAPA) is an AGM Battery. I strongly recommend an AGM Battery. I have had a DELCO and an Energizer leak in other cars. Side terminal batteries often leak if overtorqued (use only 11 ft-lbs). Sometimes they just leak. GM tried AGM battery but had a lot of problems (quality). They went to a top terminal battery (less likely to leak) in 2004 for C5s.
Old Nov 12, 2007 | 09:27 PM
2KFRC5's Avatar
2KFRC5
http://www.acdelco.com/parts/battery...al-battery.jsp
Professional Battery
The 7-Year model has the best free-replacement period (50 months) in the industry under our limited warranty
Old Nov 16, 2007 | 01:55 AM
  #33
mag red vette's Avatar
mag red vette
It would seem to me that replacing a battery with a new AC Delco would make sense if for no other reason than if you have GMPP extended warranty and the battery fails and causes damage to any of the cars components, all repairs would be covered under the extended warranty. I wonder if an aftermarket battery fails and/or causes related damage, who would be responsible for the repairs. Would GM try to not cover the repairs because the battery in question was not theirs?
Old Nov 16, 2007 | 10:18 AM
  #34
fun_n_sun's Avatar
fun_n_sun
Originally Posted by PostShawn
I heard the new AC Delcos don't leak? Is this not true?
I have an 03 with an AC Delco and it is AGM so I believe these don't/can't leak. Anyone?
Old Nov 16, 2007 | 11:32 AM
  #35
waddisme's Avatar
waddisme
My '02 with a birth date of 9/19/01 still has the original battery. I think I will just replace with a new AC Delco and a battery pad. Optima seems like it might be overkill for me as mine is a dd. Good thread with good info. Got to love this forum.
Old Nov 16, 2007 | 03:39 PM
  #36
Dave68's Avatar
Dave68
Yes, the 01-03 AC Delco batteries are all AGM and will NOT leak. The new AC Delco Professional batteries are not AGMs but their cases are significantly stronger, especially near the terminals. I have yet to hear of any 2004+ AC Delco batteries, leaking.
My 01 OEM battery is still going strong after 6.5 years.
Old Nov 16, 2007 | 03:57 PM
  #37
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
Originally Posted by tellefan
I bought mine from a Napa store. NTB also sells them but at a higher price. The famous auction site also sells them. I bought the larger size 34/78 it fits right in. The factory hold down also fits perfectly. I've read too many articles about other batteries. It seems most folks want to drive a Corvette "a fairly expensive sports car" but they want to cut corners and save money on batteries. I DON'T LIKE TO WALK! Nothing pizzes me off more than a car that won't run. David
bought my orbital from napa, best price around. i had a 2000 coupe which had evidence of a battery leak. computer was ok, but it took some work to pull everything and clean up/dissipate the corrosion from the acid.
To Replacement Battery
Old Nov 16, 2007 | 07:14 PM
  #38
Oldvetter's Avatar
Oldvetter
Well, my Excide Orbital crapped out after almost 5 years. I got over 50% back from SAM'S CLUB, put the $56 towards an Optima Redtop (SAM'S doesn't sell Orbitals anymore).
Yellow and Blue Tops are okay too, but they are deep-cycles that aren't really necessary for a car. For a boat or an RV they are good. Redtops have 6 years total warrenty, yellowtops have 2...........enough said.
Old Nov 16, 2007 | 10:36 PM
  #39
Lord Vetter's Avatar
Lord Vetter
St. Jude Donor '09-'10-'11-'12-'13
If you're going to buy an Optima, a Red Top should do just fine. Yellow and Blue Tops are sweet too, but they are deep-cycles that aren't really necessary for a car. For a boat or an RV maybe. This is just my two cents worth though.
Old Nov 17, 2007 | 08:11 AM
  #40
mike348's Avatar
mike348
I'll stay with my Delco Professional. They finally put the post back on top in 04.
