Dash inserts ?? !!!!Calling all knowledge!!!!
Old Aug 12, 2007 | 08:37 PM
Titleist320's Avatar
Titleist320
Default Dash inserts ?? !!!!Calling all knowledge!!!!
I bought some dash inserts ( stickers ) for the air bag, and I can not find a way to get these things to stick. They will look good for a few days, then they start peeling off at the edges. I have tried everything I can think of. I followed the directions all three times ( clean with alcohol, did not touch the backing with my fingers, put in place and allowed hours to dry "Even adding some heat from a hair dryer the third time, that was a tip given on the directions"
Does anyone have a way to actually get these things to stick????
Old Aug 12, 2007 | 09:10 PM
mcgilles's Avatar
mcgilles
I don't have them yet but I believe many add superglue to hold them in place.
Old Aug 12, 2007 | 09:14 PM
finallystylin's Avatar
finallystylin
superglue on mine 8 months now and still there.
Old Aug 12, 2007 | 09:37 PM
Oldvetter's Avatar
Oldvetter
Yep, superglue and a toothpick, real fun !
Old Aug 12, 2007 | 11:11 PM
Titleist320
Haha... thanks guys, it does sound like a lot of fun...
Do you add the glue to the entire back of each letter before you install or just the ends that start to peel off??
Old Aug 12, 2007 | 11:41 PM
I bought my vinyl airbag stickers from Corvette Accessories Unlimited and cleaned the area very well with rubbing alcohol. Then used tweezers and a toothpick to put the decal in place. Have had it on there for at least five years now and not one sign of peeling.
Some have used the superglue method to get them to stick but I'm not wild about that idea. A good quality decal should stick without having to resort to that.
Old Aug 13, 2007 | 01:11 AM
WetteVette's Avatar
WetteVette
I feel your pain. My decal from West Coast Corvettes didn't stick either. And I'm absolutely not going to put Super Glue on my dash! I've heard the decals from Cyberdyne Graphics are top notch & good quality. Think I may buy my next one from them.
Old Aug 13, 2007 | 01:38 AM
DeeGee's Avatar
DeeGee
If you gave it a good clean I guess its just bad adhesive.
I've also heard guys use superglue but that will destroy the finish on the dash pad. Why not try some of the rubber solution type adhesive. At least that will rub off if you decide you dont like them.
Old Aug 13, 2007 | 06:07 AM
Z06HPISFUN's Avatar
Z06HPISFUN
St. Jude Donor '07
I have the Cyberdyne Graphics dash inserts, but they didn't stick very well. Called Cyberdyne and they shipped me a second set but have yet to put them on. When I do, I'm going to use an adhesive, just not sure what to use. Not using superglue, that's for sure. Looking for an adhesive that I can remove if need be.
Old Aug 13, 2007 | 06:35 AM
travelingypsye's Avatar
travelingypsye
Clean the dash more.......... once or twice with alcohol just doesn't get it. I found the same thing. After many applications of rubber/vinyl/ leather conditioner, that stuff soaks in. Vinigar, then Dawn & water, then alcohol & lots of it. When the dash feels almost rubbery like .....it is clean..........BTW......Cyberdyne Graphics rules.
Old Aug 13, 2007 | 06:40 AM
OIF2XVET's Avatar
OIF2XVET
I can't remember where I got but I do know I bought cheap ones. I have had no issues at all and did not use super glue. I cleaned the airbag letters with alcohol and a Q-tip to get into the small spaces. Put the letters in then went back over them with a dry Q-tip to insure they were stuck on good. Again I have had no issues it may work for you as wel.
Old Aug 13, 2007 | 07:24 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Use denatured alcohol (Lowes, paint dept.) to clean the indents. I use it to clean any surface I want something to adhere to and it has never harmed anything. Alcohol just doesn't do a good enough job........
My letters stick fine after doing this.
Old Aug 13, 2007 | 08:20 AM
Oldvetter's Avatar
Oldvetter
I added glue just to the ends that started to peel off. Actually used two toothpicks, one to add glue, other to push down on decal.
Old Aug 13, 2007 | 08:28 AM
Warnberg
Guest
Posts: n/a
Why couldn't you get an auto leather dye and have someone that knows how to air brush, air brush them for you? Would that work better then stickers?
Just an idea...
To Dash inserts ?? !!!!Calling all knowledge!!!!
