Tail light problem
Old Aug 13, 2007 | 03:20 PM
Bigcountry7's Avatar
Bigcountry7
Default Tail light problem
I have seen this posted here many times but I have never seen a definitive answer and/or solution for the problem. I have a 00 cpe and sometimes when I turn the headlights on the dash and tail lights do not illuminate. I am not very electricly inclined so I wasn't sure if anyone found a solution for this problem. Thanks in advance for the help.
Old Aug 13, 2007 | 03:41 PM
DeeGee's Avatar
DeeGee
Not an easy one but a few guys have fixed that problem by cleaning up the grounds
The rear lights ground on the left rear driver's side chassis (G401). You can get to it by taking out the driver side tail light.
The other fix may be to clean the ground that’s located behind the driver’ side headlight opposite the alternator.
Old Aug 13, 2007 | 11:02 PM
Bigcountry7
Thank you DeeGee for your help.
Old Aug 14, 2007 | 12:33 AM
fst85vtt's Avatar
fst85vtt
had the same problem with my 00frc it turned out to be the multiswitch
Old Aug 14, 2007 | 12:36 AM
fst85vtt's Avatar
fst85vtt
if thats what it turns out to be gm parts direct,com 130bucks if i remember right easy fix
To Tail light problem
