Fast vs LS6
Old Aug 23, 2007 | 11:38 PM
vincentjames501's Avatar
vincentjames501
Default Fast vs LS6
Just a quick question. Which is better for the Dollar? If I were to have a FAST 90 w/ a ported TB or an LS6 w/ a ported TB, what would be the difference in power? Is it worth the extra money? I've always been taught that bigger isn't always better . At least that's what I tell my girlfriend . Is there a size that good for fairly stock cars?
Old Aug 23, 2007 | 11:44 PM
ptindall's Avatar
ptindall
For a stock motor, I think LS6 with stock TB is best. I have read 1000 times on here that the ported TB is nothing but trouble and adds zero power the a stock motor.
Old Aug 24, 2007 | 09:27 AM
Vega$Vette's Avatar
Vega$Vette
Old Aug 24, 2007 | 09:36 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Unless you have H/C Package and can take advantage of the FAST w/Ported TB you should stick with the LS6 manifold for the gains!
You'll be suprised at waht can be done and accomplished w/ the LS6 !
It's what's on mine and you can see the numbers in the sig at the bottom!
Thanks,Matt
Old Aug 24, 2007 | 09:42 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
What they said...
Peace
Chip
__________________
..................Click for
Old Aug 24, 2007 | 09:47 AM
madmatt9471
Here's a shootout article for you!
http://www.tpis.com/plog/index.php?o...Id=14&blogId=1
Thanks,Matt
Old Aug 24, 2007 | 11:32 AM
AU N EGL's Avatar
AU N EGL
Thanks,Matt
also
A fast 90/90 combo works geat on a LS2 or LS7 motor. a PP LS6 head works better on LS1 or LS6 motors.
a PP TB does work, but not if it is the ONLY component put on. That is the challenge, some guys pp the TB on and nothing else then they complain, it didn't work. Well Dahhh?
a PPTB with a Good CAI, and PP LS6 heads, PP LS6 Intake and headers, Tune, LTs, does wonders.
Old Aug 24, 2007 | 02:41 PM
kingsey's Avatar
kingsey
When i go heads and cam i'm leaning towards a ported LS6 intake.
Old Aug 24, 2007 | 04:25 PM
Z06Electron's Avatar
Z06Electron
Originally Posted by AU N EGL
also
I don't know, I did ok with the ported fast 90/90 and haven't done heads or cam yet.
Old Aug 24, 2007 | 07:07 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Fast 90/90 works well, however nothing wrong with the LS6 if money is an issue
Old Aug 24, 2007 | 08:37 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I bought the 90/90 set up and after I install it, you slow pokes can buy my LS 6 intake
Old Aug 24, 2007 | 08:52 PM
Vega$Vette's Avatar
Vega$Vette
Better hold on to it. I know a couple of guys that lost hp when they switched to the FAST.
Old Aug 24, 2007 | 09:25 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
From the tests I've seen, the Fast 90/90 flows the best, with the LS6 not too far behind. Adding one does almost nothing to a stock motor.
For a stock motor, look at it this way.
You have a straw, and now you open the bottom of the straw up real wide, is it going to improve your drinking experience? Once you add higher flow heads and cam, then your going to start sucking air harder, where that lower restriction helps. But for stock, save your money.
To Fast vs LS6
