[Z06] Reverse Lockout
Old Aug 26, 2007 | 06:32 PM
TM-Z06's Avatar
TM-Z06
Default Reverse Lockout
Does it exist?
I have a stock M12 with a B&M shifter, and for the first time missed 5th and found reverse - at 70mph. You can imagine the horrible grind that was to be. This got me thinking......do these transmissions have a reverse lockout? If so, is my solenoid shot?
Old Aug 26, 2007 | 09:15 PM
heavymetals's Avatar
heavymetals
The T56 has a reverse lockout solenoid.
Mine went bad to.
Old Aug 27, 2007 | 07:18 AM
sgmcneil's Avatar
sgmcneil
I'm not sure but I think if you installed a 1st to 4th bypass switch that disables the reverse lock out selenoid.
Old Aug 27, 2007 | 12:22 PM
TM-Z06's Avatar
TM-Z06
I don't have a CAGS eliminator plug. I have it disabled in the PCM.
Old Aug 27, 2007 | 02:24 PM
HP_Addict's Avatar
HP_Addict
This is not true. The CAGS defeat has nothing to do with the reverse lock-out.
The reverse lock-out solenoid is located on the upper passenger side of the transmission. When activated it prevents shifting into reverse at speed. You can overpower it if you press real hard, takes 2 hands for the average Vette driver. The solenoid can go bad, it also has a fuse in the engine compartment near the battery. To test it start the car and back up. If it is bad you will not be able to shift into reverse.
Old Aug 27, 2007 | 03:05 PM
TM-Z06's Avatar
TM-Z06
I check the fuse tonite when I get home. So - if the soleniod is bad - the car won't go into reverse?
Old Aug 29, 2007 | 09:10 PM
Z11409's Avatar
Z11409
Many cases it just has been the wires coming off the plug at Solenoid
Old Aug 29, 2007 | 09:48 PM
TEXHAWK0's Avatar
TEXHAWK0
The reverse lockout solenoid is separate from the skip shift solenoid. One should not affect the other, unless you connected the skip shift bypass to the wrong solenoid!
Old Aug 29, 2007 | 10:00 PM
ZO6TrailblazerSS's Avatar
ZO6TrailblazerSS
I too found reverse once at ... digits and it was not nice at all. I yanked it back so fast I only heard hell for less than a second (it seemed like an eternity), Now on occasion I have hold reverse as I start to go and then it pops right in. This is on my to do/check list...
To Reverse Lockout
