p1416 code again
Old Sep 4, 2007 | 02:14 PM
htp2000's Avatar
htp2000
Default p1416 code again
i get the famouse p1416 code again i checked the check valve the one thats hard to get thinking it was stuck .well i disconected the hose and blew through it and it seems to be fine if i suck nothing happends no suction i cant suck air so i think that it is good .what else could cause this code? all it seems to be is a one way valve my air pump is working but it seems to only run when at cold start ups and it only runs for a few minuted is it suppose to run all the time?
Old Sep 4, 2007 | 02:49 PM
Dave68's Avatar
Dave68
I don't think you can be sure that your troubleshooting method is definitive. More than likely, you will need to replace that valve. They typically last only 5 years or so.
Old Sep 4, 2007 | 02:59 PM
htp2000's Avatar
htp2000
i for sure though blowing and sucking would be a good way to check . all i have to do know i figure out how to get it off cut a hole in the fire wall
Old Sep 4, 2007 | 04:10 PM
Redvette_22's Avatar
Redvette_22
Take off the hose and spray WD-40 in it, then use compressed air to blow it all the way in. This method usually works as a temporary repair if you don't drive your car much. If you drive it a lot, then you may not need to replace the valve after using the WD-40 at all. There have been repair posts on the forum about this for a long time.
Old Sep 4, 2007 | 04:34 PM
htp2000's Avatar
htp2000
i tryed that i used a piece of old hose and pluged it to the valve sprayed wd 40 in it with air it worked for 3 days fine then came back i would love to replace it but seems to be allot of work i would think its just a one way valve whats the big deal i tryed the blowing techniqe with my mouth it seemed not to be stuck air flows fine. if you suck nothing its closed thats the way it should be hmmmm
Old Sep 5, 2007 | 12:48 PM
mattman's Avatar
mattman
I had the 1416 code and found that I had a loose exhaust clamp on the x-pipe that was installed a couple years ago. I believe this allowed some outside air to affect the O2 sensor until the exhaust pipe warmed up enough to expand the pipe and seal the leak.
After tightening the clamp a few weeks ago I have not had this code.
To p1416 code again
