Headlight Gear *Bad Surprise* - I feel SO Violated -- WTF?
Old 09-13-2007, 09:08 PM
Junkman2008
Junkman2008's Avatar
So who sells the Franker gear and what is their web address?
Old 09-13-2007, 11:01 PM
diyguy
diyguy's Avatar
Located in the sticky note.... but here is direct link...
Brent Franker Link
His site is F-bodies, but the same gear works in the C5.
BTW - The patient has healed and has completely recovered -works just like new
I did fab up a bracket just for sure. It would be hard pressed now to come apart!
Everything is 1/4 inch drive - 10mm socket (with several extensions) and end wrench and about 30 minutes off, 12 hour cure on the glue and 30 min back in. NO problems whatsoever!
Old 09-14-2007, 01:02 AM
Junkman2008
Hey DiyGuy, I understand that I will have to glue my housing back together on my 2001 Coupe when I repair it. Exactly what glue should I use?
Old 09-14-2007, 01:45 AM
kingsey
kingsey's Avatar
Originally Posted by 01Z06 Black
Whats more scary is that it could have been repaired at a dealer.
Old 09-14-2007, 03:52 PM
diyguy
diyguy's Avatar
If you go with either vendor, they will send a specialized glue in the kit. I looked up the glue (forget at the moment) from Frankers kit as I had heard the set-up time was very short. So, after an hour and it was still gooooey look up the manf on the web. Has a 3 hour window to work before it sets up. That's why it took overnight to cure.
Don't know what's in it but it dries and sands just like the material the gear case is made of. I would seriously doubt it coming un-glued.
Good Luck ----->
Old 09-14-2007, 05:50 PM
dbirdz06
dbirdz06's Avatar
What a mess!
Old 09-14-2007, 07:23 PM
vizette
vizette's Avatar
Yikes! Looked like JB Weld gooped on there. Like we used to say in electronics class "the bigger the blob the better the job!"
-Rich
Old 09-14-2007, 09:04 PM
Junkman2008
-Rich
Surely you all failed that class Rich!
Old 09-14-2007, 09:37 PM
jordanfd
jordanfd's Avatar
Hope your repair job works. If not at least you know what to order to do it right. Let's hope this is all that jack leg mechanic "fixed" Frank
Old 09-15-2007, 01:28 AM
rcknusa
rcknusa's Avatar
I went with the Franker solid brass gears since this is the second time I have had to replace the gears. I replaced both with brass gears and the rubber insert and the rubber was destroyed and in little chunks in a year. Mr. Franker and I are doing a little experiment though, he sent me one brass and one anodized aluminum for me to try. The obvious difference is the weight and the color but both fit in there real nice.
Quick Reply: Headlight Gear *Bad Surprise* - I feel SO Violated -- WTF?
