18" wheel question
Old Sep 16, 2007 | 08:32 PM
dennyb7's Avatar
dennyb7
Default 18" wheel question
Can you put on stock vette rear 18"rims, not zo6 size, with the 275-40 run flats on the fronts and run them at all 4 corners, any issues with this setup. Thanks Denny
Old Sep 16, 2007 | 09:31 PM
BADMFR's Avatar
BADMFR
St. Jude Donor '08
you can, but most people tend to have wider tires in the rear. nothing wrong with all the same though.
Old Sep 16, 2007 | 09:51 PM
Rickyh93's Avatar
Rickyh93
I've seen the rears run on all 4. I will be putting on 18x10.5's all around soon or at least by the spring.
Ricky
Old Sep 16, 2007 | 10:00 PM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Keep in mind that a stock front rim is 17 x 8.5 with a +56mm offset...a stock rear rim is 18 x 9.5 with a +63mm offset. When you work out all the math, the stock rear rims will stick out a 1/4 inch more on the front than your stock 17" wheel does. No big deal and not all that noticeable but just thought you should know
Old Sep 16, 2007 | 10:19 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Originally Posted by 4GTABODT
Keep in mind that a stock front rim is 17 x 8.5 with a +56mm offset...a stock rear rim is 18 x 9.5 with a +63mm offset. When you work out all the math, the stock rear rims will stick out a 1/4 inch more on the front than your stock 17" wheel does. not that noticeable but just thought you should know
good info!
Old Sep 16, 2007 | 10:21 PM
CHUXDRM's Avatar
CHUXDRM
Don't you need a difference in rolling diameter from front to rear for the active handling? Forget the specs, but aomebody will chime in here about that.
To 18" wheel question
