Front Bumper Lights
Old Sep 19, 2007 | 10:46 PM
kirby_24's Avatar
kirby_24
Default Front Bumper Lights
Can anyone here help me with a link or directions on how to remove the front bumper light housing off our 01 vert? I have a piece of broken bulb visable from the outside & I can not figure how to get it out without removing the whole housing. Any help would be greatly appreciated in advance.
Old Sep 19, 2007 | 10:59 PM
jdmvette's Avatar
jdmvette
Night Owl for life
manually raise your headlights.
remove black headlight bezel held by 3 screws.
reach down and feel for bulb connector.
twist and pull bulb from bottom of lense housing.
replace and reverse to put back together.
Old Sep 19, 2007 | 11:35 PM
Or, if you can't get your arm in there, raise the car and take the access panel off that is located under the front fascia. Once removed, you have complete access to the light sockets.
Old Sep 20, 2007 | 01:01 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Old Sep 20, 2007 | 01:04 AM
DeeGee's Avatar
DeeGee
I normally change the bulb by going in through the top.
If the bulb has exploded you'll probably need to pull the light unit to get the pieces out. Also if its blowing bulbs you may have a crack which is letting water in.
Best to pull the housing, get the wreckage out and check for damage. To do that you'll need to open the panel underneath.
Old Sep 20, 2007 | 01:17 AM
5W0P3's Avatar
5W0P3
I just got some new corner lenses... so i need to take the panel off from the bottom?
Old Sep 20, 2007 | 11:46 AM
sliebl's Avatar
sliebl
Yes. You'll need a 7mm nut driver, and a small 1/4" drive ratchet w/7mm socket to do the job.
Old Sep 20, 2007 | 11:47 AM
mcgilles's Avatar
mcgilles
speaking of the front marker lights, why are they partially held in place by a spring?
Old Sep 20, 2007 | 03:52 PM
kirby_24's Avatar
kirby_24
Thanks for all the help, I will remove the housing this weekend.
To Front Bumper Lights
