Grilles Gone Wild
Old Sep 30, 2007 | 11:49 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default Grilles Gone Wild
Upon buying my vararam, I purchased a set of grilles from Corvette Specialty of California for the foglight area for the purpose of protecting the intake from flying crap and hiding the intake from view.
http://www.corvettespecialty.com/cor...roducts_id=174
They Look very cool, but from a functional standpoint, their design makes them impractical. There are reinforcements about every inch or so between every bar making airflow significantly disrupted and my foglights had roughly 50% of their light blocked. Also the mounts (which are simple 90 degree aluminum brackets with double sided tape) don't look very good IMO.
In an attempt to solve this problem, I used a dremel cut off wheel to remove the reinforcements except the ones on the very edges. I used 3M mounting tape to hold them in place.
....well apparently that wasn't good enough. Upon walking to my car from the sunday starbucks break, I saw that one of my grilles had fallen off. I was amazed to later find it just a few blocks from my house on the side of the road. The Grille itself is destoryed and I will be getting ZO6 style screens (which I should have bought in the first place)
Conclusion: The CSC grilles are the perfect choice if you don't have or use fog lights and a Vararam intake.
Old Sep 30, 2007 | 11:54 PM
WetteVette's Avatar
WetteVette
Oh well, live and learn!
BTW, "grilles gone wild" - I love it!
Old Oct 1, 2007 | 12:08 AM
kikker_1999's Avatar
kikker_1999
Good info... and a mighty fine Black Vette
I grew uo in good ole Spring, Texas... Spring High Class of 82!! My parents still live there!!
Nice to see my "home town" on your avtar!!
Did you check out the Long Horn Rod Run??
Old Oct 1, 2007 | 12:34 AM
ddanis60's Avatar
ddanis60
that black with the reflection looks
i like the look. i dont like the screens much, and this is the first ive seen of the grills you have(or had). they look clean. nice car bud
Old Oct 1, 2007 | 12:43 AM
DeeGee's Avatar
DeeGee
Thats a shame because they really looked good on your Vette
Good post as it may save someone from making an expensive experiment.
Old Oct 1, 2007 | 01:22 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
Thats too bad!
...I like the black on black with the black and white emblems to boot
Sounds like practicality prevails
Old Oct 1, 2007 | 02:48 AM
Virtual Geezer's Avatar
Virtual Geezer
Old Oct 1, 2007 | 03:00 AM
97vetteman's Avatar
97vetteman
The do look good black. Why don't you buy a cheap mesh grill set off Ebay and spray them black with a rattle can! I paid about $45 for these and one of mine fell out(fording a flooded road) so when I got some replacements I used clear silicone around the outside edge so I don't lose another!
Old Oct 1, 2007 | 08:43 AM
BadYellowCorvette's Avatar
BadYellowCorvette
Really liking the black grilles!
Old Oct 1, 2007 | 09:09 AM
vettelover84's Avatar
vettelover84
Good Luck with the Z06 style grills!!!
Old Oct 1, 2007 | 09:20 AM
b98's Avatar
b98
Old Oct 1, 2007 | 11:09 AM
You'll be pleased with the OEM grills - works just fine and not one problem with them falling off in over 6 years.
Old Oct 1, 2007 | 12:19 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I have had mine on for several years now and no issues at all
Old Oct 1, 2007 | 12:21 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
97vetteman: That's the plan. I have a little extra duplicolor paint from a previous project. I'm Orderign a set from RPI designs (the have a special going on)
Old Oct 1, 2007 | 12:37 PM
jughead1's Avatar
jughead1
From: Assault is a behavior, not a device! Cypress TX
St. Jude Donor '11
I ordered and received my set of Z06 screens from RPI Designs. I am impressed with the quality. They are sent with double sided tape for mounting but I plan to install mine with velcro. I also intend to paint mine black to match the black powder coated screens that I've already have installed in all the other vents. I picked up a can of black bumper paint from the auto parts to give them a dull black finish to match the powder coat finish. We'll see how they work out.
Old Oct 1, 2007 | 12:53 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
I used there double sided tape and added velco. I went on a very spirited drive on Satuday probley around 200 miles. They were rock solid and aren't going anyware. Someday I'll pull the front bumper off and install they like a real Z06.
Old Oct 1, 2007 | 03:34 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Why do you guys use velcro?
To Grilles Gone Wild
Old Oct 1, 2007 | 05:26 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
With the Velcro you get a better hold. Unless you can get in from the bottom when you do the screens you can't really press the double sided tape on very well. With the Velcro you can really get on there tight and then do the screen also and slide it into place. Seems to work the best besides removing the bumper and bolting them in.
Old Oct 1, 2007 | 06:02 PM
jughead1's Avatar
jughead1
St. Jude Donor '11
I was told that with the velcro you can also remove the screen for cleaning, touch up or access if necessary. Slide thin pieces of cardboard between each velcro point and then the screen can be removed. It made sense to me so I thought it couln't hurt to try it.
Old Oct 1, 2007 | 06:36 PM
RedSoxFan's Avatar
RedSoxFan
Damn! I thought the post said "Girlies Gone Wild".
Sorry to hear about the mishap.
