View Poll Results: How Problem Prone is Your C5?
No Problems in the last year.
56.25%
A Few Problems in the last year.
39.58%
Constant Problems in the last year.
4.17%
Voters: 240. You may not vote on this poll
A Poll: C5 Problems in a Year
Old Jan 19, 2008 | 12:29 PM
  #61
s'noJob's Avatar
s'noJob
Default the south
Originally Posted by Hi-yo-Silver
In 2 1/2 years, the only thing that has happened is the battery went south!
well, at least the weather's better there.
s'noJob
Old Jan 19, 2008 | 12:49 PM
  #62
Gicantor's Avatar
Gicantor
In 8 months of ownership..........so far I'm not overly impressed.
1.Rocking seat issue
2.Column lock failure(in my driveway thank god)
3.TPS sensor failure
4.Headlight stalk switch replaced
5.Grinding into 4th gear(unknown cause)
6.Crazy gas gauge syndrome
7.Power seat lumbar support not working
8.Water leaks from targa top
9.New battery
It's funny cause I owned a 20 year old mustang for 4 years and only had to replace the rear brakes.
Old Jan 19, 2008 | 01:33 PM
  #63
motogib1's Avatar
motogib1
02 Coupe. Owned 1.5 years. Problems:
1. chirping belts Fix: replaced belts.
2. service ABS/Traction control light on. Fix: had EBCM repaired.
Thats it other than all the money I've spent on modifications. Thus far I love the car.
Old Jan 19, 2008 | 07:46 PM
  #64
Foosevette's Avatar
Foosevette
9.New battery
I know a dude who brought a brand new mustang lx: in 2000 and have driven the **** out of it (still is) to this day. Not ONE problem
Old Jan 19, 2008 | 07:50 PM
  #65
RonJ's Avatar
RonJ
36K miles on my 01.
Only problem was a terminal that plugs onto the TAC Module failed and put the car into REDUCED ENGINE POWER mode 12 hours from home!!
RonJ ...
Old Jan 19, 2008 | 08:32 PM
  #66
2KFRC5's Avatar
2KFRC5
I had 3 issues in the 1st year(2000):
* Loose frame ground, Vette wouldn't run
* Passenger seat belt
* Column Lock
All corrected/repaired expertly by my local Chevrolet dealer. Haven't had any issues since.
Old Jan 19, 2008 | 09:04 PM
  #67
65GGvert's Avatar
65GGvert
Well, he did have one problem. He was still driving a Mustang and not a Vette.
2003 AE convertible for 2 years, not even the smallest problem.
Old Jan 19, 2008 | 10:24 PM
  #68
bm bradley's Avatar
bm bradley
100K on a 04 coupe, A4. no engine mods. front spring broke, replaced cam and crank sensors, weather stripping replaced. some problems with the steering sensor, caused problems with the traction control warnings. 2 tire monitors.
-bmb
Old Jan 19, 2008 | 10:26 PM
  #69
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
04 vert all good here
Old Jan 19, 2008 | 11:01 PM
  #70
big gil's Avatar
big gil
02 vert with 27,000 miles. New battery and new water pump.
Old Jan 19, 2008 | 11:26 PM
  #71
No problems for mine in the past 4 years.
Old Jan 20, 2008 | 03:34 AM
  #72
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
New battery,serpentine belt,new tires,column lock fix.
That was 3 years ago,nothing else but,routine maintenance
and modding since then.
Old Jan 21, 2008 | 09:11 AM
  #73
RSchleder's Avatar
RSchleder
Default 5 years, one issue!
Only had an axle seal leak in the 5 years I've owned my 2000 vert and it was covered by the extended warrany. It has 62K miles and I've put 26K miles on it since I've owned it---great car, looking for many more years of enjoyment with it!
Old Jan 21, 2008 | 01:18 PM
  #74
Bell's Avatar
Bell
Bought a 2002 Coupe with 19K mile in 2005.
First year (+ 13K miles):
EBCM replaced
Cracked wheel - new Z06 replicas (didn't mind that one)
HVAC module replaced - my fault, shorted it out doing LED mod
redid PRND321 lights 4 times - my fault again.
Last year ( + 13K more miles):
redid HVAC and IPC lighting - issues with aftermarket gauges/lights
AIR pump check valve replaced - DIY fixed
Battery acid destroyed vacuum line - DIY fixed
Normal wear and tear:
New tires
Battery
Oil change on DIC command (usually at 5%)
$1,000,000,000 in gas (seems like it).
Existing problems:
Rocking seat.
HID conversion for headlight/foglight (I consider the OEM headlights a severe design flaw).
B2605 seat limit switch failure - nobody on CF knows how to fix this.
I've spent ALOT more $$$ on modding the car than maintenance/repair.
Old Jan 22, 2008 | 12:16 AM
  #75
ValiantSailor's Avatar
ValiantSailor
Originally Posted by Carl M. Stapp Jr.
Just a short list. If you haven't these problems, you will.
1.Steering colum lock failure
2. Wheel bearing failure
3.Complete electrical system failure (grounds)
4. ECM failure
5. ABS module failure
6. Active handling module failure
7. Steering wheel position module failure
8.Cooling fan failure (three)
9. AC compressor exploded
10. HVAC control panel light failure
11. Rocking seat
12. Daytime running lights break every time it rains
13. Oil pressure sending unit failure
14. Coolant surge tank failure
15. Power windows stick
16. Tire pressure sensors fail
17. Power seat memory failure
18. Assorted parts fall off of the interior
19. Tail light fell out
20. exterior temperature sensor failure
21. drivers side outside rear view mirror won't stay in place
22. Ac drive belt makes noise
23. HVAC door actuators won't actuate
24. alternator failure
25, water pump failure
This doesn't cover it all. It is a 2002 that I bought new, never been wrecked and , unless the dealer did it in the first 10 miles, its never been under water.
WooooHooooo you had more problems with the C5 than I have had with my 78 MGB in the last 20 years. How many miles do you drive that car a year?
Old Jan 22, 2008 | 12:50 AM
  #76
robertm98's Avatar
robertm98
Default Problems? I've had a few!
Lets see in the last 12 months. Headlight motor drivers side.
Transmission, clutch and shift rod linkage. 6spd manual
Drivers door switch
and a wiring problem I haven't been able to figure out!
I have a 98 convertible and I'm having some weird problems. I have had a few intermittent electrical problems in the past where when I'd be driving down the road every idiot light on the dash would come on, all the gauges would go down to nothing. The radio and the windows quit working. This problem would happen and then 5 miles or so later they'd all come back on and work like normal. The display would also flash reduced power and service engine soon however it didn't feel like power had been reduced.
Now I just replaced the tranny and didn't mess with any of the wiring however the battery was disconnected for a couple months. We put a new battery in and the car won't crank! All the dash lights are on, the dummy lights that is. The windows won't operate. The doors well unlock but they won't lock. We have no power to the radio and the hatch release for the convertible top isn't working. I remember that way back when when I would be driving and having these problems I would open the drivers door and slam it and the problem would go away. I did try slamming the door and that doesn't help now! I also cleaned the ground and terminals inside of it on the drivers side a pilliar and it looked fine. Whats wrong with my car? Any help would be much appreciatted! By the way the car well start if you jump it on the starter and the voltage and load tests on the battery are fine. I also tried plugging my scan tool into the car and it says vehicle not responding so its not communicatting! Thanks again!
To the cars credit I bought it new when I was in college and have driven it hard for 128,000 miles and just started having problems when I got to 80k miles and that was the known steering column lock problem and a leaking seal on the motor.
The biggest problem prior to the tranny and wiring problems was paying for a new set of tires every 6 months! lol
Even though I am a little upset with my car right now, I still love her and I'm glad I've had here and well never get rid of her!
Old Jan 22, 2008 | 07:31 AM
  #77
bassvet's Avatar
bassvet
St. Jude Donor '10
WOW glad I didn't purchase my 04 where some did.... 04 CE 38,000 miles DD and track, both straight line and road course. NO CODES only "change oil" and three sets of tires...........
To A Poll: C5 Problems in a Year
Old Jan 22, 2008 | 10:58 AM
  #78
bucwheat's Avatar
bucwheat
A/C compressor,10 months ago,no other problems ever.
Old Jan 22, 2008 | 03:29 PM
  #79
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
I've only had this C5 for about 7 months and the only problems I have had is sometimes the drivers side window doesn't want to roll up and also sometimes the drivers door will not unlock with the fob...probably is related somehow.
Old Jan 27, 2008 | 03:42 PM
  #80
AZMillVert's Avatar
AZMillVert
Cruising
I've had alot more problems than I signed up for.
Colum lock left me stranded at a football game.
Axle leaks and trans leaks cost over $1000 to fix.
Seat rocks.
Turn signals work sometimes.
Wipers keep blowing the fuse.
Steering wheel squeks.
Rear suspension squeks.
Its a 2000 with 75,000 miles.
