C5 Battery Replacent ?
Old Oct 23, 2007 | 08:12 PM
  #41
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
RED TOP only way to go
Old Oct 23, 2007 | 10:20 PM
  #42
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Originally Posted by DoomDRV
My original Delco battery in my 01 gets a lot of abuse - long periods of sitting and really cold conditions. It has proven excellent - why change whats not broke?
Because the one on my 2000 as with many others here had a problem leaking acid and causing damage to the car. The battery post on mine came off with a side of the battery.
Old Oct 23, 2007 | 10:26 PM
  #43
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Originally Posted by DeeGee
only one problem with that poll. If i vote i had a problem with my acdelco
i can not vote i now have a redtop and no problems.
Old Oct 23, 2007 | 10:35 PM
  #44
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Originally Posted by DJ_Critterus
I'm too lazy to look it up right now, but isn't the yellow top a deep cell battery? If the OP is only using the battery for cranking and stock functions, Deep Cell batteries are not the way to go
edit: tried looking it up and the website won't work for me.
Using a deep cycle battery as a starting battery
There is generally no problem with this, providing that allowance is made for the lower cranking amps compared to a similar size starting battery. As a general rule, if you are going to use a true deep cycle battery (such as the Concorde) also as a starting battery, it should be oversized about 20% compared to the existing or recommended starting battery group size to get the same cranking amps. That is about the same as replacing a group 24 with a group 31. With modern engines with fuel injection and electronic ignition, it generally takes much less battery power to crank and start them, so raw cranking amps is less important than it used to be. On the other hand, many cars, boats, and RV's are more heavily loaded with power sucking "appliances", such as megawatt stereo systems etc. that are more suited for deep cycle batteries. We have been using the Concorde SunExtender AGM batteries in most of our vehicles for some time now with no problems.
http://www.windsun.com/Batteries/Bat...ting%20battery
Old Oct 23, 2007 | 10:46 PM
  #45
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Originally Posted by timd38
The Delco batteries made by Delphi had issues with side terminal corrosion. When Delphi sold their battery group to Johnson Controls, they already had the problem fixed, so they converted everything over to their design and the problem went away.
too bad i had one of the side terminals fall out and cause a mess
Old Oct 23, 2007 | 11:26 PM
  #46
Dave68's Avatar
Dave68
I've mentioned this many times, but I'll say it again: The latest AC Delco batteries (since 2004) have significantly strengthened cases with emphasis placed on the ares around the terminals. What was a weakness is no longer an issue. As evidence, see their 50-month free replacement warranty - best in the business.
Old Oct 23, 2007 | 11:34 PM
  #47
Dave68's Avatar
Dave68
AC-Delco tried AGM batteries but they were junk. In 2004, GM changed from Delphi produced batteries in the Corvette to Johnson Controls made batteries.
Just get an Optima Red Top.
Almost ANY AGM will die a quick death if not charged adequately (short trips or infrequent startups). Do a search on Optima Redtops and you will find many, many complaints of early deaths.
Keep an AGM charged and you will be rewarded. It seems that AC Delco assumed that owners would treat their batteries as I do - 10-15 mile trips and 3 times per week use. My AC Delco AGM has served me well for almost 6.5 years and is still going strong. Is that junk? Not by a long shot. In fact, it is the best battery I've ever had in the 33 years of driving I've accumulated.
Old Oct 23, 2007 | 11:46 PM
  #48
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Yes sir I understand, my reply was to someone with a stock 01 battery asking why he should not change something that was not broken.
Old Oct 24, 2007 | 12:14 AM
  #49
gallibonos's Avatar
gallibonos
Yeah, i've been busy playing the game of life an doing the G.I. Joe thing. Of course my post count here on the forum had to suffer
Thanks for your service!!!!
Old Oct 24, 2007 | 12:39 AM
  #50
Virtual Geezer's Avatar
Virtual Geezer
If your car is not driven regularly, I strongly suggest a 'battery tender.' The OE Delco in my 1992 Vette lasted 10 YEARS with the help of a battery tender. Can't b*tch about that!
I have had great luck with Delco and Exide batteries.
Old Oct 24, 2007 | 05:58 PM
  #51
timd38's Avatar
timd38
My engineers took enough of them apart to confirm what I said. The Delphi AGM batteries were junk. You just got one of the few good ones.
Old Oct 24, 2007 | 06:54 PM
  #52
Mordi's Avatar
Mordi
I guess I must have have gotten one of the few good ones too, since I also have a 01 orig battery and it still runs like a champ
Mordi
Old Oct 24, 2007 | 07:31 PM
  #53
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi brzman -
If you even get this far in this thread....
Yes - you can get by with a Wal-Mart el-cheapo battery, or whatever you want.
One criterion that I have to put on my battery is that it has to at least look like it belongs in the engine compartment.
Now I don't have all chrome engine covers and painted stuff - but I do take some pride in the look of my engine and the associated components under the hood.
All of that said, I think the Optima Red Top is the best suited battery for my C5's.
I have one in my Z06, and coincidentally, I will be buying one for my wifes C5 as today her Sears Die-hard went completely dead all at once.
So - yes - Optima's are much more expensive than the CHEAPEST option, and somewhat more expensive than the "better quality" batteries offered at Autozone and OReilly's etc.
But on a car that I will spend $120 for floor mats, why is it such a big deal to spend $150 on a quality battery that also looks good under the hood?
Pay your money, take your choice.
best regards -
mqqn
Old Oct 24, 2007 | 07:38 PM
  #54
istsme98's Avatar
istsme98
Optima
Old Oct 24, 2007 | 08:50 PM
  #55
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by brzman
My battery is playing games.
After reading some awful reviews about AC DELCO
what battery's can you recommend when the time came ?
thanks
Some people have problems with AC Delco and some don't. Some people have problems with Optima RedTop and some don't. Some people have problems with Sears Die Hard and some don't....and on and on and on...Get my drift?
I have had no problems in 2+ decades in my Corvettes so far with
Old Oct 24, 2007 | 09:17 PM
  #56
Dave68's Avatar
Dave68
Mordi
There are many 01-03 C5 owners who are still using their OEM AC Delco AGM. Not only are they NOT junk, but many have outlasted the best Optima. How many Optimas last 7+ years?
Read on.......
http://forums.corvetteforum.com/show....php?t=1026859
Old Oct 24, 2007 | 09:32 PM
  #57
highdesert's Avatar
highdesert
From: I’m sittin’ at a bar on the inside. Waitin’ for my ride on the outside in Verdi, NV
St. Jude Donor '09-'10-'11
Read on.......
My original Delco lasted almost eight years with no leakage whatsoever.
Old Oct 25, 2007 | 02:05 AM
  #58
Thickraybans's Avatar
Thickraybans
Odyssey925
