traction control warning
Old Oct 22, 2007 | 08:01 AM
Cindy's Vette's Avatar
Cindy's Vette
Default traction control warning
Well, I thought I'd go for a nice fall ride yesterday and the car won't run. I got a traction control warning and the engine went into reduced power mode. After turning it on and off 5 times it decided to run but the check engine light is now on. What does all this mean and how can I keep driving the car? I'm going to the dealer to get the rear end sealed this week but I'd like to know what I'm talking about concerning the warning. Help. CIndy
Old Oct 22, 2007 | 09:13 AM
tboneinsc's Avatar
tboneinsc
Default What Codes?
Hey I had the same thing happen to mine recently and a TC Module was changed out. The part cost $290 and with labor I think it was in the low $400.
You really need to post what code is showing for someone to give you a better diagnosis.
Good luck!
Old Oct 22, 2007 | 09:16 AM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
read how to check the codes and post them here.
Old Oct 22, 2007 | 09:51 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
Here is a site that will tell you how to pull your codes and what they mean. Take a piece of paper and pen with you and write them down.
http://www.stengel.net/diccodes.htm
Old Oct 22, 2007 | 11:44 AM
Bill Dearborn's Avatar
Bill Dearborn
The site has codes with Descriptive headings but those headings do not tell you what the code means. They just tell you where to start looking.
Bill
Old Oct 22, 2007 | 03:11 PM
Cindy's Vette
Thanks for the tip on how read the codes. There are 13 codes but I think a lot are from disconnecting the battery during storage but 2 of them may help. C1275 & U1064. I looked them up from the code site but I don't know what they mean or what the abbreviations mean. Could you please help me understand them? Thanks Cindy
Old Oct 22, 2007 | 05:07 PM
DeeGee's Avatar
DeeGee
Cindy, the codes will have either C (current) or H (history) after them. If you have so many they could be from a long time ago. Neither of those codes are common for AH/TCS problems.
Best bet is to reset them after jotting down the numbers. Run it to see if the problem reoccurs and jot down whether its H or C. If its C it'll be easier to work out the problem. If its H it means its an intermittent snag. TCS and AH problems can be very intermittent and hard to diagnose.
Post up what you get
Old Oct 23, 2007 | 08:05 AM
Cindy's Vette
Thanks, I'll do that and wait for it to reoccur.
To traction control warning
