[Z06] down force
Old Oct 22, 2007 | 07:43 PM
Bigstik's Avatar
Bigstik
Default down force
I was just curious if anyone knew approximately how much down force the C5 Z gets at say......100MPH.
Old Oct 22, 2007 | 08:07 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
From what I've seen it appears as though your answer would be "negative". These cars appear to produce LIFT at high speeds, not downforce...
Old Oct 23, 2007 | 08:19 AM
AU N EGL's Avatar
AU N EGL
Here you go
http://www.sae.org/servlets/productD...D=2002-01-3333
Data for front and rear lift, total drag, and lift/drag (L/D) ratio are provided for each test configuration. The cumulative effects of the aerodynamic changes evaluated in his program, calculated at 192 KPH (120 MPH), increased front down force by 318 N (72 Lb.), and rear down force by 770 N (173 Lb.). Lift/drag ratio was improved from -0.597 to -1.016. These changes increased total drag by 381 N (86 Lb.). Further testing lowering ride height 2.5 cm rear and 5.0 cm front reduced drag by 326 N (73 Lb.) and resulted in a L/D ratio of -1.247.
Old Oct 23, 2007 | 08:35 AM
Bigstik's Avatar
Bigstik
Originally Posted by AU N EGL
Thanks Tom!!
Old Oct 23, 2007 | 08:06 PM
zulatr's Avatar
zulatr
anyone download the file?
To down force
