[Z06] Need help with TI install
Old Oct 25, 2007 | 03:25 PM
jolitaly's Avatar
jolitaly
Default Need help with TI install
I got a shop to put on the mufflers but we ran into a problem when we realized that there were no rubber brackets that the mufflers slide into to keep them in place. I just ordered the parts from my local dealer and was just wanting to know how to pull off the rear bumper cover and if there is a way to put these on without the removal of the bumper. Here is a pic of the parts necessary for the install of one side of the mufflers, the parts for the other side will be here tomorrow.
Old Oct 25, 2007 | 03:28 PM
AlwaysInBoost's Avatar
AlwaysInBoost
no need to remove the rear bumper to install the muffler hangers. there should be two studs sticking out on each side to bolt the 2 - 13mm nuts to. Thats all you need to do.
Old Oct 25, 2007 | 03:29 PM
Z06Electron's Avatar
Z06Electron
They can be accessed with the bumper on. Why didn't your car have them? The Z06's and coupes mount in the same way. How was the current exhaust mounted? Holes should still be there if it was removed.
Old Oct 25, 2007 | 03:38 PM
jolitaly's Avatar
jolitaly
The holes are there but there are no bolts to attach the hangers. The bolts that I have pictured need to be put in but I don't see how because there is bumper reinforcement foam in the way. When I was looking at it, it looked like I would have to pull the bumper foam off first and then set the bolts. Can the bumper foam be pulled off with the bumper still on?
Old Oct 25, 2007 | 03:44 PM
Z06Electron
could have rattled off up inside, still wondering how the current exhaust was mounted?
Just looked at mine and judging from the pics of the part, and how mine looks, if your bolts are in fact not there, you will be pulling the bumper foam
Old Oct 25, 2007 | 03:46 PM
jolitaly's Avatar
jolitaly
On the passenger side it did rattle into whatever it is, I just don't know how to get to it to reset the bolts
The guy that had the car before me put in Borla straight pipes there were no mufflers.
Old Oct 25, 2007 | 03:49 PM
Z06Electron
ohhh, bet you're pissed he didn't just put 2 nuts on that thing. Sorry, but good luck.
Old Oct 25, 2007 | 03:57 PM
AlwaysInBoost
ohh, well that sucks then. Maybe they make an anchor type bolt with a sleeve, like you would use for hanging something in a hallow wall. Or maybe you could fit a U-bolt in one end and out the other w/o having to remove the bumper.
I've never had to remove my bumper so I can't help ya with that.. sorry.
Old Oct 25, 2007 | 04:01 PM
jolitaly's Avatar
jolitaly
That might be a good idea I will check Home Depot. Thanks!!!
Old Oct 25, 2007 | 04:02 PM
jolitaly's Avatar
jolitaly
Anymore suggestions would be great. Thanks!
Old Oct 25, 2007 | 04:11 PM
Z06Electron
It's permanent, but you could have them use regular bolts and weld them to the frame.
Or you could tap the frame and then use bigger bolts so it could thread into the frame from the bottom.
Old Oct 25, 2007 | 04:15 PM
AlwaysInBoost
I'm not 100% positive but I believe the place where those bolts went thru was fiberglass... maybe he can JB Weld them, lol.
Old Oct 25, 2007 | 04:18 PM
jolitaly's Avatar
jolitaly
Its either fiberglass or plastic.
Old Oct 25, 2007 | 05:17 PM
Last C5's Avatar
Last C5
That's why you never take those nuts off. An old cat back will slip out of the rubber and the new ones will slip in when you're doing exhaust work. I have heard of someone using a magnet and managing to fish the stud bracket back into place. Otherwise, you're right, the tail end has to come off. A lot of screws, but not that difficult.
Old Oct 25, 2007 | 06:08 PM
Z06Electron
On my Z06 it's metal. It mounts right onto the frame...???
You can see on this burn vehicle where the mounts would be, unfortunately it looks like you have to access them from the side of the back frame through the hole.
Old Oct 25, 2007 | 07:02 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi jolitaly -
The place where the holes for those studs is metal - it is the rear frame crossmember....
You might try something like bolts and this :
http://www.pemnet.com/fastening_products/atlas/
best regards -
mqqn
Old Oct 25, 2007 | 08:52 PM
1FUNC5's Avatar
1FUNC5
I have had these bolts go up into the hole before. You have to take an extendable magnet and work one end back into the hole. This can be done without taking the bumper off. Also, to my knowledge these are not welded in....
Steven
To Need help with TI install
Old Oct 26, 2007 | 10:10 AM
jolitaly's Avatar
jolitaly
Steven
I beginning to think they should have welded them. I'm taking a half day today so hopefully I can get this done. Thanks for the help!
Old Oct 26, 2007 | 10:57 AM
briann510's Avatar
briann510
You can take out your taillight lens and actually get a drill through the opening and there is more than enough room inside to drill vertically on top of the bumper frame a top hole and then use a long threaded rod with washer/bolt on top and go though the bumper framing and out the bottom (hardest part is making sure the top holes aligns pretty darn close with the bottom ones). The holes wont ever be seen and then you have a stud coming out the bottom. Yea its funky rigged, but there aren't a "hole" lot of options.
Old Oct 26, 2007 | 12:14 PM
jolitaly's Avatar
jolitaly
So you're saying to drill through the top of the bumper frame to get to have access to the bottom? What about the bumper reinforcement foam?
