Lifter Noise???????
Old Oct 26, 2007 | 08:59 AM
Steve Zamcheck's Avatar
Steve Zamcheck
Default Lifter Noise???????
My friend has a 2002 automatic C5 with 45,000 miles. He complains about lifter noise on cold start-up. I told him that is the nature of this engine. Am I right? Please advise.
Old Oct 26, 2007 | 09:37 AM
dankhts's Avatar
dankhts
hmmmmmm... I don't think it's supposed to be that way - my '02 is at the stealership right now for the same problem, but on my car, the noise dosen't go away when it gets warmed up - the dealer told me there should be no lifter/valve train noise at all.... most of my friend's vettes are "noise free" in the engine.... I'm waiting to see if they fix it - still under warranty btw...
Old Oct 26, 2007 | 01:08 PM
GRUNIE's Avatar
GRUNIE
Piston slap. Mine does the same thing on cold starts but goes away after a couple of minutes. Just give the car time to warm up before mashing the pedal.
Old Oct 26, 2007 | 01:21 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The report you will get is "Lifters Bleeding Down When Cold". I know, it happened to mine a couple of years ago. You'll need to replace the lifters.
Old Oct 26, 2007 | 02:04 PM
Black 'n Tan's Avatar
Black 'n Tan
St. Jude Donor '07
Hasn't Chevy had lifter leakdown problems since the 50's? YEASH!!!!!!!
My Dad's 60's Chevies sounded like Diesels when they started. My Corvette just has the usual piston slap noise when cold.
John
Old Oct 26, 2007 | 02:15 PM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Piston slap....very common, especially over 25,000 miles. When the pistons and the heads all reach operating temperature, all the dissimilar metals are expanded and "snug up". Should only take about one or two minutes to quiet. If it takes much longer, you may have some piston/ring issues to check out.
Old Oct 26, 2007 | 03:11 PM
Phanni's Avatar
Phanni
It's piston slap. similar, but different, sound.
Old Oct 26, 2007 | 03:13 PM
dgrant3830's Avatar
dgrant3830
Piston Slap will come from the bottom end and more than a second or two means there are larger issues. Lifters tapping will come from the top end and a tap sound rather than a deep knock.
To Lifter Noise???????
