Instructions for replacing antenna?
I have a C5 and my antenna died so I checked on here and bought a small stubby antenna online(forgot where I bought it and it came with a small mountaing screw, but I do not see any way to mount it to the old base and I am having trouble replacing it. I removed the taillight and used some pliers to cut off the old broken antenna and I pulled it down, but need some instructions on which wires to disconnect(to disable to motor sounds everytime I turn on the radio) and also looking for some instructions on how I can mount these short stubby antennas. Has anyone seen any instructions out there or any ideas on an easy way to do this?
Thanks,
Dan
You need to completely remove your electric antenna assembly and install a fixed mast antenna assembly. Then your shorty antenna should screw onto the threaded stud at the top of the antenna base.
You can buy a new assembly from Gene at GMPARTSHOUSE, a site supporting vendor. You can buy a used assembly from the other Gene at GENE'S KAR SHOP, another site supporting vendor. Both can be found on the main menu page, in the column to the left.
You could post a want to buy ad in the CF classifieds, asking for a used Z06 antenna assembly. It'll plug into the radio antenna lead and will have no electrical wires to worry about...no more motor sound, either.
BIGHANK
Thanks,
Dan
http://forums.corvetteforum.com/show...post1561462757
