Where to get wheel spacers.
Old Oct 27, 2007 | 04:31 PM
Z28STYLE23's Avatar
Z28STYLE23
Default Where to get wheel spacers.
I want to put the C6 Z06 brakes on my C5 Z. I put my wheel on a C6 Z the other day and i need about 3/16- 5-/16 more room to make it fit perfect with some clearance. Where can i get a wheel spacer? only need for the front.
Old Oct 27, 2007 | 06:43 PM
tiojames's Avatar
tiojames
Contact Doug Rippie at DRM. They make a machined billet aluminum spacer and have the 90,000 psi studs for them. I have them on the front of my vert with the C6Z06 brakes.
Old Oct 27, 2007 | 06:54 PM
BADMFR's Avatar
BADMFR
St. Jude Donor '08
www.thunderracing.com
http://www.thunderracing.com/catalog...vid=7&pcid=215
Old Oct 27, 2007 | 07:49 PM
Z28STYLE23's Avatar
Z28STYLE23
What size did you get?
Old Oct 27, 2007 | 09:05 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
I wouldn't trust a "universal" stud design like that... especially since none of the sizes are hub-centric. You get what you pay for.
Try:
http://www.livermoreperformance.com/...acers.html#H&R
-or-
http://www.dougrippie.com/drm/wheel_components.htm (scroll to bottom)
Old Oct 27, 2007 | 11:42 PM
TM-Z06's Avatar
TM-Z06
Get adapters instead of spacers - they're safer
http://www.vbandp.com/SearchResult.aspx?CategoryID=62
Old Oct 28, 2007 | 12:55 AM
130NA5's Avatar
130NA5
I have a pair of DRM 3/8 inch spacers and DRM extended studs I will let go for $125 plus shipping. Paypal accepted.
Old Oct 28, 2007 | 11:18 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Yes, but adapters are not physically possible to construct in the width required by the OP (~ ¼").
Notice that in the link you provided, they are all a minimum of 1" and none of them are hub-centric.
Old Oct 28, 2007 | 12:15 PM
johncbourg's Avatar
johncbourg
St. Jude Donor '09
Old Oct 29, 2007 | 08:03 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Let me know if you have any questions.
Randy
Old Oct 29, 2007 | 08:08 PM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Chris, I'm not sure putting your C5 Z06 wheel on a C6 Z06 will give you the answer you need as I think you'll close to a 1" spacer to get clearance over the C6 Z06 caliper.
Here's a post I did last year once I figured out the proper offsets (it took me 3 sets of rims to get it right)
http://forums.corvetteforum.com/show....php?t=1512629
PM me if you have any specific questions
To Where to get wheel spacers.
