Check Engine light - turn off???
Old Nov 3, 2007 | 06:20 PM
maxvalley's Avatar
maxvalley
Default Check Engine light - turn off???
Car sitting for a month, battery got a little to low to start her, neutral and rolled her out of garage and jump started, all's well but the check engine light is on, no reason other then battery was low - HOW DO YOU RESET CHECK ENGINE light to make it go off without wasting time at stealership, telling them nothings wrong??? Thank in advance.....
Old Nov 3, 2007 | 06:55 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Reset button (right side where the Options, etc. buttons are located on the dash).
Check for codes:
http://forums.corvetteforum.com/show....php?t=1625418
More information on codes:
http://www.gearchatter.com/index10.p...e0914816539da2
If you have codes, post them up.
BTW - very possible that the battery needs replacing if it's over 3-4 years old.
Old Nov 3, 2007 | 06:56 PM
WWK888's Avatar
WWK888
Check your DIC for any codes first.
Old Nov 3, 2007 | 07:37 PM
maxvalley's Avatar
maxvalley
Thanks guys, no DIC code just Check Engine Light after the battery went low, and the CEL went out all by it's lone some....fingers crossed!
Old Nov 3, 2007 | 07:41 PM
WWK888's Avatar
WWK888
Sometimes you just have to cycle through the ignition a few times and it will reset itself.
Old Nov 3, 2007 | 08:04 PM
RonJ's Avatar
RonJ
Check for codes:
This is an excellent site, as good as having a service manual!!
Thanks for posting it.
RonJ ...
Old Nov 3, 2007 | 11:28 PM
Jet-Jock's Avatar
Jet-Jock
Clear your codes. Because you had a low voltage condition on the PCM from the dead battery. Be sure to get it charged up or replaced.
1) Turn on the ignition but don't start the engine.
2) Press the "RESET" button to turn off any warning messages
3) Press and hold "OPTIONS"
4) While holding "OPTIONS", press "FUEL" four times within a 10-second period.
Initially, on-board diagnostics go into an "Automatic Mode" which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. If none are present in a given module, you will see "No More Codes" on the display.
To reset the codes once in manual mode, press and hold "RESET" until it displays "NO CODES".
Everything should return to normal.
Old Nov 4, 2007 | 03:16 AM
DeeGee's Avatar
DeeGee
At least with a top post AC Delco on an 04 you should be safe from leaking battery.
As suggested I'd still check the codes and clear them down. If you had a powerr interrupt you'll have a lot of lost comms codes which would confuse any future diagnostics.
To Check Engine light - turn off???
