Bang after cold start?
Old Nov 4, 2007 | 11:09 PM
UKXPAT's Avatar
UKXPAT
Default Bang after cold start?
Whenever I start driving in the morning (from a cold start) after about 3-5 mins there is a "bang" coming from the passenger side rear fender area. It only happens once and then not again for the rest of the day??? It sounds like an object hitting the hollow plastic inner fender.
I looked in the trunk storage areas and everything is secure, so I know it's not anything rolling around in there.
Has anyone else had this experience?
Any help would be greatly appreciated as I'd like to fix this problem before my last resort...taking it to the stealership
Old Nov 4, 2007 | 11:15 PM
Daybreak22's Avatar
Daybreak22
That kinda sounds like backfiring.
Old Nov 4, 2007 | 11:19 PM
UKXPAT's Avatar
UKXPAT
No it's not coming from the rear end (I have Borla Stingers and love it when it burbles) but behind the passengers side seat.
Old Nov 4, 2007 | 11:25 PM
noahdr's Avatar
noahdr
I don't own a vert but maybe it has something to do with your roof. Just a guess really.
Old Nov 4, 2007 | 11:28 PM
dataporter's Avatar
dataporter
Looks like you have a convertible. Maybe you have a problem with the automatic antenna? That's back there.... Run the antennae up, clean if off and lube it with silicone or something, just a suggestion
Old Nov 4, 2007 | 11:32 PM
UKXPAT's Avatar
UKXPAT
I thought that too but it happens both when the roof is down and up. Good guess though!
Old Nov 4, 2007 | 11:35 PM
UKXPAT's Avatar
UKXPAT
My antenna is up as soon as I start so I know that it's not stuck and working loose but it also sounds like it's farther forward than that...it's sounds very close to the rear of the passenger seat. Thanks for the suggestion though!
Old Nov 4, 2007 | 11:42 PM
dataporter's Avatar
dataporter
I was thinking maybe the antenna was sticking before it got to the top and then bang that last inch
The gas tank and the fuel pump is right behind the seats...
Old Nov 5, 2007 | 12:07 AM
UKXPAT's Avatar
UKXPAT
Ahhhhh good to know, thanks for that . Luckily I have a GMPP warranty, if it comes to that!
Old Nov 5, 2007 | 01:32 AM
DeeGee's Avatar
DeeGee
Could it be something inside the fender well?
Its reasonably easy to take off the wheel and take out a few of the screws to get a flashlight in there and take a look. You can also get the rear taillight out in 5 seconds flat and see if theres anything loose in the antenna area.
This pic shows whats in there
Old Nov 5, 2007 | 01:50 AM
UKXPAT's Avatar
UKXPAT
That sounds like a good idea, I think I'll take a look in the wheel well and see if there's anything loose in there. Thanks for the diagram as well! It just seems strange to me that it only happens once and always at the same time
Cheers mate!
Old Nov 5, 2007 | 07:43 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Check to see if you have a loose pipe hanger or perhaps the pipe is smacking the bottom of the car for so reason. Could be the initial torque causing the pipe to hit once.
Regards,
The Pup
Old Nov 5, 2007 | 10:48 AM
UKXPAT's Avatar
UKXPAT
Regards,
The Pup
Now that's exactly what it sounds like, I'll definitely check that one out...thanks for the idea!
Old Nov 5, 2007 | 10:58 AM
EtidW's Avatar
EtidW
Sounds like it may be heat related if it takes the same 3 to 5 minutes to happen which would indicate the exhaust system. May be a pipe or cat or muffler clamp. Kust a thought.
Old Nov 5, 2007 | 11:24 AM
UKXPAT's Avatar
UKXPAT
I'm also thinking that it's heat related as I checked my gauges and it only happens after the engine gets past 133 degrees .
Old Nov 6, 2007 | 01:40 AM
UKXPAT's Avatar
UKXPAT
Ttt
Old Nov 6, 2007 | 03:11 AM
RTE61's Avatar
RTE61
I think what your hearing is what drove me crazy when I first got mine until I had my girlfriend drive while I sat in the passenger seat heard the thump. It was just the flap slamming open on the ac/ heater. When it goes from recirculate to fresh air after car detects outside temp. Hope this helps.
To Bang after cold start?
Old Nov 6, 2007 | 08:22 AM
Rupert's Avatar
Rupert
Another thought your parking brake could be sticking on one side, when things get warm enough it releases. If you can, try not using the parking brake and see if you still get the noise on the next start up.
Old Nov 6, 2007 | 10:44 AM
UKXPAT's Avatar
UKXPAT
Thanks for the feedback but I don't usually have the A/C on, but I will make sure that it's off and see if it still happens.
Old Nov 6, 2007 | 10:45 AM
UKXPAT's Avatar
UKXPAT
That sounds like it could be a possibility, I'll definitely give that a try! Thanks for the idea!
