it friggin worked....
Old Nov 10, 2007 | 09:18 PM
JustForFun's Avatar
JustForFun
Default it friggin worked....
i replaced the engine in my C5 few weeks ago....(another story)
when i put in the new engine i replaced both belts and all the tensioners..(GM parts)
for some odd reason I had this squeaky belt or pulley that drove me crazy and could not get it to stop. It made my whole engine swap sound like crap with all the chriping/rattle sound....was bad.
This morning i remembered seeing a old GM tech use a bar of soap on the belts for the same issue.....I went into the bathroom closet, got a bar of DIAL soap...went outside and while engine was running and belts were squeak...squeak...squeak....i touched the bar of soap to the running belt. within about 10 seconds the sound was gone. I held the bar of soap there til about half of it was burned/ground off....
today i drove the car about 100-125 miles...still no squeal
Wondering how long it will stay gone. Man im so much happier at present.
Old Nov 10, 2007 | 09:20 PM
JB666's Avatar
JB666
I'm not sure, but I'd say that Dial's a real eye opener!!
Old Nov 10, 2007 | 09:24 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
I thought Zest was the eye opener?
Old Nov 10, 2007 | 09:26 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
Good way to clean the motor in the rain!!!
Old Nov 10, 2007 | 09:27 PM
JustForFun's Avatar
JustForFun
i dont know whats in it that made it work...or how...but i can tell you it worked like magic.
JB666's Avatar
JB666
Raise your hand, raise your hand if your sure!!
WWK888's Avatar
WWK888
Even if it doesn't last long at least you know your belts are clean...don't you wish everyone used Dial?
Old Nov 10, 2007 | 09:29 PM
4DRUSH's Avatar
4DRUSH
No Zest is squeaky clean
JustForFun's Avatar
JustForFun
i did kinda have a fresher smelling interior after the treatment...really..
Old Nov 10, 2007 | 09:34 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Very old remedy
I posted it here in a few posts re the squeak issue - got the raspberry from the young ones - maybe they will take heed - doubt it
Old Nov 10, 2007 | 09:36 PM
JustForFun's Avatar
JustForFun
Originally Posted by AC54ME
Very old remedy
well i can promise it worked....my AC belt was awlful it was squeaking so bad....embarrassing actually. Honestly made whole car sound better.
Old Nov 10, 2007 | 09:38 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I gotta ask, on the ribbed side or smooth?
JustForFun's Avatar
JustForFun
smooth
Old Nov 10, 2007 | 10:25 PM
lil vette's Avatar
lil vette
Try Irish Spring...It has that clean, freshly showered scent..
It works great at keeping the elephants from crossing roads
at night, preventing a crash. Has worked great for me.
Have not had any close calls with elephants.
Old Nov 10, 2007 | 11:06 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
Very old remedy
Old Nov 10, 2007 | 11:41 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Very old remedy
It may remedy the noise, but it does nothing to actually fix what caused the noise to begin with.
Two types of problems can cause a squeak on this type of belt system. The most common, a dry or worn bearing on a idler or tensioner pulley. If the bearing itself is making the noise, lubing/soaping the belt probably won't cure this, unless it's for reason two...
If the belt itself is making the squeak, and the noise is cured by lubing it, it is usually attributed to a wobbling or misaligned pulley. The intermittent side load is causing the friction and squeak. A bad pulley bearing (idler/tensioner) can wobble under load and cause the chirp even though it may still spin freely/quietly upon inspection with the belt off. Or, the crank balancer is also well-known to seperate and wobble excessively, often causing belt squeak as the first symptom.
Either way, soap might mask the noise, but it fixes nothing.
Old Nov 10, 2007 | 11:50 PM
omarcoolguy's Avatar
omarcoolguy
i had the same prob till i used a gator back belt
To it friggin worked....
Old Nov 11, 2007 | 02:09 AM
DeeGee's Avatar
DeeGee
Great tip thanks
Mine is a weekend car normally. I just have the start of that annoying squeek when its been idle for the week. if I use it every day no problem. Maybe I'll try the soap trick and see if it buys me some time.
I see new belts on the horizon
Old Nov 11, 2007 | 03:47 AM
mechron's Avatar
mechron
take it from an old time mechanic, soap works but it's old skool (50s-60s) in the 70s we just sprayed the belts at idle with a squirt of WD-40, way faster-belts quiet instantly, lasts a long time, no chance of soap/fingers being ripped outa your hand and the belts dont slip.
Old Nov 11, 2007 | 05:24 AM
Junkman2008's Avatar
Junkman2008
Funny, my squeak wasn't the belt or the tensioners. It was a ever so slightly loose header bolt.
