Loosing Coolant?
Old Nov 13, 2007 | 12:37 PM
RABVET427's Avatar
RABVET427
Default Loosing Coolant?
I have a friend with a 2004 convertible who recently noticed that his coolant level was down approximately 1 gallon but can not see any leaks. He has subsequently refilled with water/antifreeze and so far it seems Ok.
Is this normal or is something going on the he should be concerned about?
Thank you.
Old Nov 13, 2007 | 01:32 PM
HMannini's Avatar
HMannini
Cruise-In X Veteran
St. Jude Donor '09
Thank you.
I just went through the same problem, It turned out to be the water pump.
