Octane in your Vette
Old Nov 14, 2007 | 08:02 PM
97c5vette's Avatar
97c5vette
Default Octane in your Vette
I've been using 87 octane when filling up my C5. Kind of middle of the road octane.
Would it actually be a bad idea to use unleaded 83 octane or would there be no noticeable difference. On the other end, is super 93 octane that much better?
What about those Octane additives, at $15 a bottle Yikes!
What do you guys use and why?
Old Nov 14, 2007 | 08:50 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
91 or better is recommended for our cars, not 87. The car is tuned for 91, it will run ok for awhile, but timing will be changed and you will get pinging later on.
Not a good idea to run anything under 91.
Octane additives will not boost your octane at all, maybe 1/10th of a point, read the cans. Use a good cleaner from time to time (techron/sea foam, etc) you'll be fine.
Old Nov 14, 2007 | 08:56 PM
97c5vette's Avatar
97c5vette
As usual, thanks screw991le
93 octane it is
Bob CTS's Avatar
Bob CTS
Per manual:
Use premium unleaded gasoline with a posted octane of
91 or higher for best performance. You may also use
middle grade or regular unleaded gasoline rated at 87
octane or higher, but your vehicle’s acceleration may be
slightly reduced. If the octane is less than 87, you may
get a heavy knocking noise when you drive. If it is bad
enough, it can damage your engine.
Old Nov 14, 2007 | 08:58 PM
spdislife's Avatar
spdislife
Don't even think about putting 83 octane in it. I can't recall ever seeing such a low octane at a pump
91 or better is what you need
Old Nov 14, 2007 | 09:07 PM
jrose7004's Avatar
jrose7004
I wouldn't run less than 91.
Old Nov 14, 2007 | 09:42 PM
yaknow's Avatar
yaknow
91 or higher when I can get it
Old Nov 14, 2007 | 09:44 PM
hawaiiC5's Avatar
hawaiiC5
St. Jude Donor '09
always 92 with mine
Old Nov 14, 2007 | 10:01 PM
WetteVette's Avatar
WetteVette
Did some C5's come without owners manuals?
Old Nov 14, 2007 | 10:14 PM
97c5vette's Avatar
97c5vette
To Bill H.
Some of us not only recently bought our C5's but bought them USED and they didnt come with your 'owners manual'
It's 'senior' comments like yours that drive the new members away from asking questions. Honestly, if your comments are only to be a smart a**, no need to make them!
Old Nov 14, 2007 | 10:40 PM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
I use 93 which helps prevent pinging, something you want to avoid in any car, especially one of high performance.
Old Nov 14, 2007 | 10:49 PM
WetteVette's Avatar
WetteVette
To Bill H.
OK...I admit it. I was being a sarcastic a-hole. If you weren't such a newbie, you'd know that.
But it just seems that the answer to your original question is so obvious! You have a high performance sports car. Why would there be any question in your mind as to what kind of gasoline to run in it? High performance engines take high performace gas! Sure, it may run on something less, but why risk damaging your engine, or not getting all the performance your car was designed to give.
Unless I am way off base here, and you are totally unaware of the differences in the various octanes of gasoline. If so, I an sorry for my comments.
Tip: Stay away from Off Topic! You'd never survive!
Old Nov 14, 2007 | 10:53 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
How about 95 octane with up to 10% ethenal, will that 10% of corn gas hurt?
Old Nov 14, 2007 | 11:37 PM
Mr. Couture's Avatar
Mr. Couture
If you really want to find out, keep using 87 octane...don't worry, the $100 you'll save will help for the new rebuild
Old Nov 14, 2007 | 11:41 PM
WetteVette's Avatar
WetteVette
Hey, be nice! You're gonna scare off all the new guys!!
Old Nov 14, 2007 | 11:44 PM
Mr. Couture
Sorry, I couldn't help myself
Old Nov 15, 2007 | 12:00 AM
Icewind Dale's Avatar
Icewind Dale
First thing i did when i got my c5 was order an owners manual because mine did not come with one. But i have asked much dumber questions so don't feel bad 97 c5 vette. I find WetteVette humorous.
To Octane in your Vette
Old Nov 15, 2007 | 12:05 AM
Corvette Don's Avatar
Corvette Don
I use at least 91, but even then I dont like using that!
Old Nov 15, 2007 | 12:06 AM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
To Bill H.
I also understand. My first C5 didn't have an owner's manual either. There are many avenues to obtain one such as Forum Vendors like GM partshouse. You can also download them off of a number of GM/Chevy websites
Old Nov 15, 2007 | 12:17 AM
Chemdawg99's Avatar
Chemdawg99
BTW, OP, on another note. It would be advisable to use only top-tier gas in your Vette. The reason you want to follow the manufacturer's guidance with regard to octane level is the fact that you have a high-compression engine. using 91 or higher top-tier gas will assist your engine with piston crown cooling and carbon build-up. You should also treat your tank with Techron octane booster if you have been using 87 octane gas in your car. Here is a link to a list of top-tier stations:
http://www.toptiergas.com/retailers.html
It is more expensive to buy top-tier gas, however, in the grand scheme of things, you will save yourself a ton of potential engine issues down the road
