BSM's?????
Old Nov 15, 2007 | 10:35 PM
TransAm2002's Avatar
TransAm2002
Default BSM's?????
I want to take my body side moldings off, but don't want to have a different color paint underneath them. The car is a 03 Z06 torch red. Has anyone had paint discoloration from the body side moldings? (like the car faded some and the paint is brighter underneath the moldings?) Thanks for the info and help.
Old Nov 15, 2007 | 10:36 PM
rustyguns's Avatar
rustyguns
paint might come off!
Old Nov 15, 2007 | 10:39 PM
WetteVette's Avatar
WetteVette
Not if done right.
There have been many threads started about how to safely remove BSM's. Do a search.
Old Nov 16, 2007 | 01:43 AM
DeeGee's Avatar
DeeGee
I dont think I've seen any threads where discoloration was a problem, although the older the C5 gets the more likely it becomes. particularly in the desert sun
The main problem I've heard is where cars ahve had a partial respray on the door and the BSM has not been removed. It left a line on removal. Only heard one or two of those. Had one member who got it wrong taking them off and damaged the paint. Pretty rare though. Most have no problems
Old Nov 16, 2007 | 09:02 AM
serotta's Avatar
serotta
I just did mine, 03 black Z. 30lb test fishing line, two wooden dowels cut short to fit inside my hand. I drilled a small hole in each dowel centered. I threaded, knotted, then wrapped the fishing line around one, and knotted the threaded end in the other. Slowly "sawed" the line from one end to the other, rolling it off like dental floss as I rolled the other dowel wrapping the used line. Fishing line broke a couple of times if I tried to hurry it. I knotted it again and continued. Molding came off both sides in about 15 minutes. It took about 2 hours to clean the glue residue. My thumbs and fingers were sore from rolling and scraping. I finished with some cleaner, swirl remover, glaze, and wax. Can't tell they were ever there.
http://www.z06vette.com/forums/showthread.php?t=107193
Old Nov 16, 2007 | 09:23 AM
steve8's Avatar
steve8
The paint problems I have heard of apply more to the removal of hood or trunk emblems where the sun poses more of a problem. Good luck.
Old Nov 16, 2007 | 10:33 AM
GrandSportRob's Avatar
GrandSportRob
My car is a black 99..Couldn't tell there was ever a bsm after I got it off and cleaned it up...DO IT!!!!!
Old Nov 16, 2007 | 10:54 AM
mike348's Avatar
mike348
The only problem you would probably have is if any panel was ever repainted. You can always put it back on.
Old Nov 16, 2007 | 01:51 PM
bucwheat's Avatar
bucwheat
Hell, if the color is different ,put em back on. I wish mine had molding on it.
Old Nov 16, 2007 | 01:56 PM
waupachino's Avatar
waupachino
I have read several posts where this has happened to Forum members, but it is not common.
Old Sep 14, 2008 | 12:39 AM
Matth3w's Avatar
Matth3w
St. Jude Donor '09-'10
Just out of curiousity - if the entire car has been recently repainted, does that increase the chances of pulling off the paint when you remove them? I have to call my body shop on Monday, not sure if they put the moldings back on yet or not, but if they have, is it a problem to remove them?
To BSM's?????
