Dumb Question number 976!
Old Nov 24, 2007 | 08:22 PM
Ta-taaa's Avatar
Ta-taaa
Default Dumb Question number 976!
The front Spoiler/Air Dam, what is its exact purpose? Is it just for looks? If it's removed, will it effect high speed performance?
Told ya.. Dumb question!!
I'm working on Dumb question number 977!!
Old Nov 24, 2007 | 08:25 PM
vettes4fun's Avatar
vettes4fun
Air flow through the radiator and air lift
Old Nov 24, 2007 | 08:26 PM
stormrider's Avatar
stormrider
If you are referring to the three black rubber pieces between the front wheels and the nose, the middle one directs air into the radiator and I believe the side pieces help reduce lift and drag.
Old Nov 24, 2007 | 08:27 PM
Bethlehem Bob's Avatar
Bethlehem Bob
St. Jude Donor '08
It is meant to direct airflow into the cooling system and air intake for the engine......don't recommend removing it.
Old Nov 24, 2007 | 08:29 PM
army2000's Avatar
army2000
St. Jude Donor '11
It's there to deflect air from going underneath your car. Very important during high speeds. Ever seen a NASCAR or F1 race where the car's front end tips up and flies off the track? Same thing can happen to you on the highway. The front piece is flexable so you won't break it off on a driveway. DO NOT remove it.
Old Nov 24, 2007 | 08:33 PM
RonJ's Avatar
RonJ
It's main job, besides directing air, is to clean the top of parking curbs and speed bumps!
RonJ ...
Old Nov 24, 2007 | 08:42 PM
oaks99's Avatar
oaks99
oak
stormrider's Avatar
stormrider
RonJ ...
and they do an outstanding job at that
Old Nov 24, 2007 | 08:44 PM
UKXPAT's Avatar
UKXPAT
RonJ ...
Old Nov 24, 2007 | 08:46 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
RonJ ...
Old Nov 24, 2007 | 08:49 PM
army2000's Avatar
army2000
St. Jude Donor '11
http://wings.avkids.com/Book/Sports/...ce_car-01.html
Old Nov 24, 2007 | 08:52 PM
Ta-taaa's Avatar
Ta-taaa
You guys are killing me!!
Well that's what I was thinking. I did remove the to corners. They where just wore out from ummmm,,,, Cleaning the parking lot..
I thought it looked better with out them.. I am on my way to order new corners!
Old Nov 24, 2007 | 08:56 PM
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
The sides come off when you install a ACI chin spoiler.... Both our cars had to have the side removed for the front spoiler's....
Old Nov 24, 2007 | 09:03 PM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Roadkill scoop.
Old Nov 24, 2007 | 09:15 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
It is all pretty much covered and I scraped me quite frequently when I drive and they are cheap to replace when you need to and it is great you ordered new ones
Old Nov 24, 2007 | 10:30 PM
ljthe2nd's Avatar
ljthe2nd
Originally Posted by 99mallett
Roadkill scoop.
This is the correct answer, all the rest are
Old Nov 25, 2007 | 12:43 AM
Exactly.
To Dumb Question number 976!
Old Nov 25, 2007 | 12:48 AM
JesseB's Avatar
JesseB
St. Jude Donor '08
Old Nov 25, 2007 | 01:35 AM
moserbe's Avatar
moserbe
STEP BACK FROM THE AIR DAMS!!
Old Nov 25, 2007 | 03:28 AM
DeeGee's Avatar
DeeGee
The center air dam is there to shape the airflow under the car but it also directs air into the radiator and is essential. Your temps will go through the roof without it. You can see how the flow is shaped up into the intake from this (terrible) pic.
The side sections are to smoothe the airflow (aerodynamics). Without them you have a flat plate in the airflow which causes form drag. You'll get turbulent air at the tips and it will ruin the flow under the body of the car. That will affect ride and handling. I'd say you'd be OK below 70 but at speeds above that the car would become unstable
I posted this diagram a while ago to try to explain it.
