[Z06] LS9 is here!
Old Nov 26, 2007 | 10:54 PM
ERACERX's Avatar
ERACERX
Default LS9 is here!
Old Nov 26, 2007 | 10:57 PM
xtremejimmy's Avatar
xtremejimmy
wow. that thing looks like it has some nice belt wrap.
Old Nov 26, 2007 | 11:21 PM
ptindall's Avatar
ptindall
Wow. For some reason I was assuming roots blower like all the Fords, but that is centrifical. At least that will keep the hoods low.
Old Nov 26, 2007 | 11:23 PM
ptindall's Avatar
ptindall
If you look closely, you can see it has two belts. One for the left and one for the right.
Old Nov 26, 2007 | 11:38 PM
slwhite's Avatar
slwhite
I hope they do away with the second "hood". I am referring to all the plastic covering the engine. I hate that stuff. It hides the mechanicals of the engine, which I like to see. I hope they spend a few extra dollars and clean up the appearance. This "second hood" stuff is a trend that has been going on in a lot of cars over the last few years.
My wife's 2006 Hemi Charger RT is a perfect example. You open the hood and what do you see? A gigantic cheap looking piece of silver plastic covering the whole engine. They got it right with the SRT8 version. They junked the plastic and cleaned up and painted the engine. It looks fantastic.
Old Nov 26, 2007 | 11:41 PM
ptindall's Avatar
ptindall
Would you believe my fuel rail covers are in my attic, not covering my fuel rails? What is the purpose of covering even the fuel rails and the coils? Function IS beauty!
Old Nov 26, 2007 | 11:49 PM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
Made this post over tech
That is awesome.
I love the intercooler.
Interesting TB and it looks like the inlet could be ported already.
Supercharger pulley doesn't look easy to change either.
Is that a 10 rib setup.... I could go on and on looking at those pictures.
Quite the serpentine system for sure
Z06PSI's Avatar
Z06PSI
http://www.ls1tech.com/forums/showthread.php?t=821235
Better pictures
Old Nov 26, 2007 | 11:55 PM
Z06PSI's Avatar
Z06PSI
Old Nov 26, 2007 | 11:56 PM
Z06PSI's Avatar
Z06PSI
Looks like an alternator and A/C belt and another for everything else.
Take that damn cover off. Get some tall polished valve covers, relocate the wires, polish the intercooler as well with some body matched paint for the lettering and that will be bad ***.
Old Nov 26, 2007 | 11:59 PM
u4ick's Avatar
u4ick
Where do you see a centrifugal at?
Old Nov 27, 2007 | 12:04 AM
TheDVS1's Avatar
TheDVS1
Probably the nicest integration of supercharger and engine I've ever seen. What a beauty! I was expecting something more tacked-on.
Old Nov 27, 2007 | 12:05 AM
1slo6's Avatar
1slo6
DAMN!!!!!!!!!!!! time to c what a smaller pulley and some tuning will do.....
Old Nov 27, 2007 | 12:10 AM
slwhite's Avatar
slwhite
I must admit I am a little confused about what I see. What I initially thought was a centrifugal supercharger could be the power steering pump because I can't see it anywhere else. If what I see is the supercharger, it is not obvious how the air enters and exits the unit. This can't be a Roots-type setup because of the intercooler design and location. Confusing.
OK. Now I get it. It is a Roots-type. The supercharger is hiding UNDER the intercooler. That was unexpected. The thing that some think is a centrifugal supercharger must actually be the power steering pump.
Old Nov 27, 2007 | 12:28 AM
u4ick's Avatar
u4ick
Air is entering the valley area and being compressed up into an intercooler and back down with intake runners...........
Old Nov 27, 2007 | 12:36 AM
BurnoutKid's Avatar
BurnoutKid
from what I can see (and a whole lot of guessing) it looks like a positive displacement blower. the air enters through the front, right next to the pulley then is forced up into the middle of the intercooler, the hot air flows sideways through the bar and plate setup then back down into the cylinder heads. the picture of the intercooler alone is upside down I think. this is just a guess from a kid, so take it for what its worth.
Old Nov 27, 2007 | 12:45 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Yay for twin screw
To LS9 is here!
Old Nov 27, 2007 | 12:51 AM
Z06PSI's Avatar
Z06PSI
You are correct.
Old Nov 27, 2007 | 12:54 AM
bgreen83's Avatar
bgreen83
Just cant wait to see the car as well!! It looks clean as hell though
Old Nov 27, 2007 | 12:56 AM
bullitt4110's Avatar
bullitt4110
sould be interesting....
