areodynamics
Old Nov 28, 2007 | 01:35 PM
frcftw's Avatar
frcftw
Default areodynamics
what makes the frc less areodynamic then the hatchback and what can i do about it?
Old Nov 28, 2007 | 01:37 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Obviously the back window and rear deck....what can you do about it?
You can either enjoy what you have and not worry about it or sell your car and buy a coupe.
Old Nov 28, 2007 | 01:42 PM
max'svette's Avatar
max'svette
St. Jude Donor '11
WTF??!!!
frcftw's Avatar
frcftw
i understand that but why wouldnt the longer rear deck lid give you more down force?
Old Nov 28, 2007 | 01:48 PM
spider94r's Avatar
spider94r
Maybe it does. Downforce usually creates more drag. You can have lots of downforce and high drag, or low downforce and low drag.
Any car without wings isn't going to generate much downforce though. Why do you care?
Old Nov 28, 2007 | 01:50 PM
frcftw's Avatar
frcftw
i was just curious ive always heard they were less areodynamic and just wondered why.
Old Nov 28, 2007 | 02:05 PM
army2000's Avatar
army2000
St. Jude Donor '11
As someone else stated the roof line and longer rear deck gives the FRC a higher coeficient of drag. However, if I remember correctly, GM stated that the top speed of the FRC/convertible is only 5mph slower than the coupe. In everyday driving, you should not even notice. So what your car can only go 170mph...I wouldn't sweat it.
Old Nov 28, 2007 | 02:08 PM
frcftw's Avatar
frcftw
im not sweating it i was just curious but thanks
Old Nov 28, 2007 | 02:11 PM
AU N EGL's Avatar
AU N EGL
the FRC is also lighter then the coupe
Old Nov 28, 2007 | 02:54 PM
YELLOHHH's Avatar
YELLOHHH
I'll take "the shape" for $500.
and I'll take "nothing" for $1000 and the win.
Old Nov 28, 2007 | 04:18 PM
DeeGee's Avatar
DeeGee
I hadn't realised the CD was different.
My guess would be that the steeper pitch of the rear window will cause the boundary layer to break away causing vortices and disturbed air. The airflow over the more "cigar" shaped rear of the coupe will cause less drag.
Old Nov 28, 2007 | 04:56 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Yes you can do something about it get a Caravaggio conversion
Old Nov 28, 2007 | 05:05 PM
Zilla's Avatar
Zilla
Coupe is faster than the Z06 but Z06 is quicker
Old Nov 28, 2007 | 05:36 PM
Z06Electron's Avatar
Z06Electron
it is caused by the downforce, but the handling at higher speeds is also improve slightly by this. Most track cars are more concerned with handling and downforce, than top speed.
Just keep modifying your car until it is redline limited. Then it won't matter whether you have a coupe or frc because they will both top out at the same.
Old Nov 28, 2007 | 07:44 PM
zTrek's Avatar
zTrek
The contours of the rear hatch lid produces less trailing vortices than the FRC does. As someone else pointed out, the differences are so minimal as to have no consequence in normal driving - even at interstate speeds.
Old Nov 28, 2007 | 08:31 PM
Whiteonrice's Avatar
Whiteonrice
Yep if you put 4:88 gears or something in your FRC or Coupe then you will both top out or redline at say 125. No need for slick aerodynamics. For some reason the C-5R and the C-6Z and R are all Coupes.
Rick
Old Nov 28, 2007 | 08:33 PM
Z06Electron
Rick
or you could do h/c or supercharger on both and they'd both top out around 200, but whatever floats your boat.
To areodynamics
Old Nov 28, 2007 | 09:33 PM
frcftw's Avatar
frcftw
head and cam is chillin in my room headers are already onthe car with the bottle
Old Nov 28, 2007 | 09:37 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
And what is more important to you?
Old Nov 28, 2007 | 09:47 PM
JDaniel's Avatar
JDaniel
St. Jude Donor '08-'09
With full exhaust and blackwing I got my car to 160 pretty quickly with a 220lb passanger and luggage... so aerodynamics dont much matter to me.
