[Z06] Customized partition
Old Dec 3, 2007 | 09:16 AM
Bigstik's Avatar
Bigstik
Default Customized partition
I just wanted to give a shout out and thanks to Hogfish for the partition template. Worked like a charm and I managed to craft this for the Z. See what ya think!!
Please excuse the spots on the camera. I guess I need to clean it.
Old Dec 3, 2007 | 10:48 AM
crazyv6's Avatar
crazyv6
Nice work!
Old Dec 3, 2007 | 12:56 PM
stock z06's Avatar
stock z06
what was your total cost in materials?
i would'nt mind maing one myself.. it looks sweet
ed 2002 Z06
Old Dec 3, 2007 | 01:04 PM
Bigstik's Avatar
Bigstik
I had the 1/2" plywood already, but the felt was like $10, the spray adhesive was about $5, i added some spray on soundproof stuff for like $5, and the plexiglass window was like $.49 each for two 8 x 10 sheets. Total work was probably like 2 hours. so a grand total of $20-$23 and 2 hours labor.
Old Dec 3, 2007 | 02:55 PM
teddyca's Avatar
teddyca
I would like to do this as well. Any chance you can share the template measurements with us.
Old Dec 3, 2007 | 03:08 PM
irokru's Avatar
irokru
look'en good. wonder if 1/4 ply would work or do ya need 1/2 to keep it snug?
Old Dec 3, 2007 | 03:13 PM
angeladave2002's Avatar
angeladave2002
I made mine from 3/4" plywood. I would think 1/4" might be too thin to hold in. I covered both sides with dynomat (peel & seal). The improvement in sound reduction was HUGE!! I pulled it down when driving to test and was shocked at how much quieter it was. I have Borla Stingers so my drone was noticable. I have the file in AutoCad if anyone needs it. I can also convert to PDF if necessary.
Old Dec 3, 2007 | 03:26 PM
Bigstik's Avatar
Bigstik
As Dave mentioned above I think 1/4" would be a little too thin. And also as mention the noise reduction is amazing. I took it out one day during a drive and almost couldn't hear myself think. I can actually talk on the phone and drive at the same time. I too can send the file if anyone wants it. Just PM me with your email address.
Nick
Old Dec 3, 2007 | 03:51 PM
BADMFR's Avatar
BADMFR
St. Jude Donor '08
I made my own and put subs in it(full enclosure).
I would say 1/2" material to make a sturdy partition.
Old Dec 3, 2007 | 04:08 PM
teddyca's Avatar
teddyca
Nick
PM sent Nick, Thanks
Teddy
Old Dec 3, 2007 | 04:18 PM
Bigstik's Avatar
Bigstik
Teddy
I sent you the template in both autocad and PDF.
Old Dec 3, 2007 | 04:19 PM
Bigstik's Avatar
Bigstik
Thats pretty nice. Do you have a shot from the back?
Old Dec 3, 2007 | 04:31 PM
BADMFR's Avatar
BADMFR
St. Jude Donor '08
Here ya go. This one is 8.5" deep, but depending on your subwoofer airspace needs I've made them only 4.5" deep which is much less intrusive into the trunk area.
Old Dec 3, 2007 | 04:32 PM
teddyca's Avatar
teddyca
I got it. Thanks again
Old Dec 3, 2007 | 07:00 PM
USA1 427's Avatar
USA1 427
My only suggestion would be to have put some sort of batting between the board and the carpet to even the finish out. If you would have done that, you wouldn't be able to see the square glass outline. Other than that, nice job.
Old Dec 3, 2007 | 08:17 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
You did a very nice job on your partition, unfortunately I purchased one long before I knew about the DYI template. That was thoughtful of you to add the little window so the kids have a bit of light while riding in the trunk!
Old Dec 3, 2007 | 08:50 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Okay, someone shoot me the template in PDF. I can't do the CAD stuff. I have been thinking of having the wife buy me one for Christmas. If I can build it for less than that, why not.
PM sent.
To Customized partition
Old Dec 3, 2007 | 09:11 PM
Bigstik's Avatar
Bigstik
Luckily the felt is in 2 pieces and can come off the one side. Right now my attention is on headers. But after i get those on then I am going to take the front sheet of felt off and put a small piece of foam to fill in the sides. But right now its serving more function than form.
Old Dec 3, 2007 | 10:20 PM
DERJ's Avatar
DERJ
My setup:
Old Dec 3, 2007 | 10:33 PM
USA1 427's Avatar
USA1 427
