'01 z06 oil burning issues
Old Dec 9, 2007 | 10:40 AM
coolafresh88's Avatar
coolafresh88
Default '01 z06 oil burning issues
Hey guys im looking at an '01 z06, and i am familiar with the oil consumption problems that many of the 01 z06's had. The vehicle was built in october of 2000. I know that they corrected the problem in the later 2001's, but i was wondering if anyone has an early built 01 z06 and was curious to hear about this problem.
Old Dec 9, 2007 | 11:45 AM
bobby777's Avatar
bobby777
The majority of all 01--had NO oil issues--the ones that did was from driving around at 3500 rpm in 2nd gear--ring flutter--not to worry--
Old Dec 9, 2007 | 12:48 PM
coolafresh88
yeah i know not all of them had the problem, i just heard a lot of ruccus about the ones that did and i was a little concerned
Old Dec 9, 2007 | 01:22 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Most don't know what they're talking about... if you get an '01 and drive it hard it will burn more oil.
Many people hardly drive their cars and if they do they change the oil every 3000 miles and don't see much if any oil consumption.
If you follow the oil life monitor on the DIC and drive the car hard you will see a good bit of oil consumption. If you follow the DIC you will be changing the oil 6000-9000 miles depending on conditions.
The ring package wasn't changed until '02. My car burnt 1 quart every 1000 miles until the re-ring in early '04 now it doesn't burn any between 6000-7000 mile oil changes.
There are two sources of oil consumption:
1. The actual rigngs from the oil control ring
2. The valley cover under the intake manifold where the PVC system vents pressure. The oil/air seperator seal can go bad.
When my car was fixed under warranty they replaced the valley cover and the ring package.
Get the car and enjoy it... if it burns a few quars it's not that big of a deal.
Old Dec 9, 2007 | 02:34 PM
coolafresh88
has anyone seen the amount of oil being consumed decrease, by changing to a different brand of oil? ive heard that if you use castrol syntec it helps with the problem, anyone ever see any results?
Old Dec 9, 2007 | 04:21 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
umm..thats a problem...there should be no ring flutter at all like any other year.
bottom line, avoid 01s unless it had a ring job done to it.
Old Dec 9, 2007 | 05:02 PM
Cobra4B's Avatar
Cobra4B
Owning my car through that "era" everyone tried everything. Some swore thicker oil worked, some swore that the rings just to 30,000 miles to break in because the motor was broken in on synthetic oil.
In the end it's all BS... '02+ cars have no issues on 5w30 and being run from birth on syn oil.
I run 5w40 Amsoil because I track my car.
Old Dec 9, 2007 | 05:32 PM
John G Pircsuk's Avatar
John G Pircsuk
I have an '01 with NO issues. I'm the second owner and the guy that ordered the car hadn't done any work related to the issue.
2001 Coupe, MY, custom black rear & GS stripes, New Era Performance Tuned, Vortex Intake/PowerDuct & Velocity Stack, Borla Stingers & X-pipe, B&M Ripper w/Delrin, custom boot, front/side Z06 screens, BLACK powdercoated C6 OEM wheels, McGard splined nuts, blacked-out tails, Stainless Fuel Door, etc.
Old Dec 9, 2007 | 06:27 PM
GrandSportRob's Avatar
GrandSportRob
Why take that chance?? There's plenty of C5's out there..Go for an 02 or later..I bought used and wouldn't even consider an 01...
Old Dec 9, 2007 | 07:37 PM
coolafresh88
bump
Old Dec 9, 2007 | 07:50 PM
georgec114's Avatar
georgec114
Z06 didn't have the problem...Enjoy
Old Dec 9, 2007 | 11:20 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
You had to drive like a complete idiot to have oil problems in a 2001 Z06.
Old Dec 9, 2007 | 11:26 PM
Dave68's Avatar
Dave68
EVERY C5 will lose some oil. Ask anyone who has a catch can! Some of the oil that is lost will be replaced by moisture, so even though the dipstick looks good, oil has been lost, plain and simple.
That being said, I must also mention that some 01s used more oil than did other year C5s, but this was NOT the norm. And despite tighter tolerances related to engine builds, oil use still varies from car to car, regardless of year. The quandry is: How do you know before you buy? Perhaps a statement of oil usage as measured by dipstick readings (no perfect, but better than nothing) that is signed by the seller would be beneficial if a buyback was included in the "guarantee"?
Old Dec 10, 2007 | 08:35 AM
bobby777's Avatar
bobby777
01s use more oil because they were built looser--more H/P--get what you want just make sure its a LOW mile jewel--lots of beat op junky Z06s out there--I rather have a nice queen than a 20 footer regardless of the year--
Old Dec 10, 2007 | 09:12 AM
divitasbluepitbulls's Avatar
divitasbluepitbulls
I own a 2001 Z06 and do not have the oil burning issue. No ring work or engine work at all has been done. All I do is take names at night and kick asses in the morning with it! Oh, I have 35K on the ticker too.
Old Dec 10, 2007 | 09:13 PM
coolafresh88
anyone ever had their engine re-ringed at their own cost? curious as to how much you paid at a gm dealer
To '01 z06 oil burning issues
