Headlight Upgrade
Old Dec 14, 2007 | 07:38 PM
GO_BLUE_VETTES's Avatar
GO_BLUE_VETTES
Default Headlight Upgrade
I want brighter low beams. What is my best bet on a replacement bulb? Sylvannia Silverstar Ultra? Some other item?
I don't want to drop $$$$ for HID.
Thanks,
Old Dec 14, 2007 | 07:42 PM
1dog's Avatar
1dog
Had the original Silver Stars and switched to the Ultras and did not notice any difference at all, except that the Ultras weren't as white.
Old Dec 14, 2007 | 09:09 PM
jdmvette's Avatar
jdmvette
Night Owl for life
HID kits are cheap. if you go with the halogen "upgrade" you'll be nothing short of disappointed.
Old Dec 14, 2007 | 09:31 PM
Z06Aggie's Avatar
Z06Aggie
Stock on the left - Toshiba 9011's on the right!!
Old Dec 14, 2007 | 09:48 PM
diyguy's Avatar
diyguy
For just some more in pocket change the HID bulb kit will put a on your face. With HIR's even (at around $60), the stark contrast to HID's is still lackluster at best........
Old Dec 14, 2007 | 10:06 PM
Z06Aggie's Avatar
Z06Aggie
Did my picture not show up?
Old Dec 14, 2007 | 10:15 PM
ALLEGRO's Avatar
ALLEGRO
With very little and easy modification, you can put 9005 (high beam) bulbs in your 9006 bulb socket. It is very easy and can be done with simple tools.
This is the method I chose to increase my night vision.
Good Luck
Old Dec 14, 2007 | 10:48 PM
99 vett babycar's Avatar
99 vett babycar
[QUOTE=ALLEGRO;1563176582]With very little and easy modification, you can put 9005 (high beam) bulbs in your 9006 bulb socket. It is very easy and can be done with simple tools.
Good Luck
[/QUOTE
do a search- ther's a writeup somewhere on how to do it- takes all of 15 minutes
Old Dec 14, 2007 | 11:01 PM
IDM's Avatar
IDM
like the others posted doing all of the other little tricks won't help hardly at all and wont be worth the money. The only way to fix the lighting problem is with HIDs. It takes 30 minutes to install, think of it as a safety feature if you are worried about spending 150 on it. Coming from someone that knows, I did the high beam to low beam mod, then silverstars, then HIRs, euro HLs, then HIDs with the euro HLs. I was pissed each time until I got the HIDs in and then I was overwhelmed with light!
Old Dec 15, 2007 | 12:27 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
HID 9006 5000K bulbs in stock housings Cost $150
The pattern was really annoying with all the hot spots and glare...the solution:
HID D2s Bulbs in hella 90mm housings with customized headlight housings. Cost $320 and a whole bunch of dremel cutoff wheels.
Old Dec 15, 2007 | 01:36 AM
DeeGee's Avatar
DeeGee
Or the other option which is not as popular recently is to go for the Euro headlights. They have a much sharper defined beam pattern. With the harness mod you can fit 135/90 dual filament bulbs.
http://www.pfyc.com/pc/VT1003/VTLIGH...d+Options.html
Old Dec 15, 2007 | 01:49 AM
jrprich's Avatar
jrprich
Hey DeeGee,
I looked on the link and started poking around.........look at the cost for the replacement bulb $2,699.00
for ONE bulb
http://www.pfyc.com/pc/GN1016/VTLIGH...ment+Bulb.html
Makes the ACA HID conversion seem like chump change
Old Dec 15, 2007 | 01:54 AM
DeeGee's Avatar
DeeGee
Originally Posted by jrprich
Hey DeeGee,
for ONE bulb
Thats funny I think Brian may want to edit his price on that item
Theyre about $35 a pop online. My whole kit with bulbs was only about $350 a few years ago.
Old Dec 15, 2007 | 04:26 AM
Choreo's Avatar
Choreo
I installed these Euros about 2-1/2 years ago and still the best upgrade I have done in 7 years. These put out the prefect amount of light and in just the right pattern. I paid about 300+ at PFYC with the HD harness and I bought a couple extra PIAA bulbs at the same time; however, I am still on the original bulbs and I do 90% of my driving at night.
On a scale of 1 to 10, I give these a solid "10", and I don't give out 10's. Some people prefer the nausiating, headache blue tint of some HID units, but these put out a perfect daylight color temperture and the single lense metal design looks much better than the split American plastic cans. When you hit the hi-beams it looks like a plane is landing over the top of your car.
Old Dec 15, 2007 | 07:11 AM
rws.1's Avatar
rws.1
With HID kits available for under $150 delivered...
Don't waste your $$$ on anything else.
I went Silverstar then HIR and finally HID...
Thankfully eBay is there to sell my past experiments....
Old Dec 15, 2007 | 07:16 AM
GO_BLUE_VETTES
So is this the kind of setup you guys are talking about?
http://cgi.ebay.com/ebaymotors/6000K...spagenameZWDVW
Are these $1xx decent quality or just the cheapest crap someone can sell and call it HID?
Old Dec 15, 2007 | 10:18 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Hey DeeGee,
for ONE bulb
holy crap!! for that $$ you could have your car retrofitted with NSX HID dual projectors.
To Headlight Upgrade
Old Dec 15, 2007 | 10:56 AM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Look at DJ Motorsports on the supporting vendors tab.
Davis' kits are great ... I wasted my money on Silverstars and other "brighter" bulbs, they do not compare to the HID conversion. Buy them today, this is one mod that you'll enjoy!!!
Old Dec 15, 2007 | 11:03 AM
jdmvette's Avatar
jdmvette
Night Owl for life
[URL="http://cgi.ebay.com/[/URL]
this seller comes highly recommended.
Old Dec 15, 2007 | 09:18 PM
ROJ#79's Avatar
ROJ#79
Good Luck
