Is this normal?
Old Dec 16, 2007 | 08:03 PM
vettegator005's Avatar
vettegator005
Default Is this normal?
So i was changing my oil and popped off the oil cap and just happened to notice that a little layer of dark yellow sludge looking matter was on the top of the oil cap. Is this cause for concern? When i drive i always look to see if its still there and sometimes it is sometimes its perfectly clean. The car is perfectly fine no problems at all its a 99 with 46000 miles lots of mods. can anyone help?
Old Dec 16, 2007 | 08:06 PM
c5Cruiser's Avatar
c5Cruiser
From: Corona CA - "An Armed Society is a Polite Scociety"
That's new to me. Is it foamy?
Old Dec 16, 2007 | 08:08 PM
vettegator005
not foamy more thick and kinda oily.With little specs of condensation on the inside of the oil cap as well.
Old Dec 16, 2007 | 08:26 PM
Jet-Jock's Avatar
Jet-Jock
Amsoil will look yellowish.
Old Dec 16, 2007 | 08:35 PM
jrose7004's Avatar
jrose7004
I've never seen that!
Old Dec 16, 2007 | 08:38 PM
Oldvetter's Avatar
Oldvetter
Some people have seen a brownish buildup there. I wouldn't worry about it, but if you want piece of mind, do an oil analysis. Blackstone Labs is where I send my oil, cost is $20-25.
Your oil on the dipstick looks okay ? No milkly white color (water in oil) right?
Old Dec 16, 2007 | 08:44 PM
vettegator005
Oil on dipstick looks perfect and the build-up is kinda dark yellow or light brownish.
Old Dec 16, 2007 | 08:51 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
Sounds like you've got a bit of moisture in your crankcase. If your car has sat for awhile it could be natural condensation. Since you are changing the oil, just keep an eye on the inside of that cap for awhile. Hopefully it won't re-appear. Sometimes it's an early sign of head gasket failure, hopefully that is not the case.
Can some of the 'Vetterans" here think of other places in an LS1 where coolant can get into the crankcase?
Old Dec 16, 2007 | 09:11 PM
c5streak's Avatar
c5streak
I get the same thing from time to time on both my vehicles. I think it's just from a lot of short trips, where the engine does'nt have a chance to build up enough heat to get rid of any condensation in the crankcase. If the stick looks good and the "residue" isn't milky and fresh, I'd say your okay. As stated before, an oil analysis will confirm either way. Good luck.
Old Dec 16, 2007 | 09:23 PM
PFMC3's Avatar
PFMC3
Condensation Just keep a eye on it.
Most common fail point for coolant in engine is head gaskets.
I have seen some other reasons but it was a abused motor.
Old Dec 16, 2007 | 09:40 PM
vettegator005
Yeah my vette gets very few highway miles almost all short trips in town id say 1-5 miles at the most per trip.
Old Dec 16, 2007 | 09:54 PM
Oh 2 Fun's Avatar
Oh 2 Fun
Well there ya go.
I know you can buy alcohol based dryer additives for fuel tanks, but I'm not sure about an oil additive.
Anybody know of something?
Old Dec 16, 2007 | 10:02 PM
Bob CTS's Avatar
Bob CTS
Keep an eye on it, I had that on a Ford and it was due to leaking intake gaskets letting coolant into the oil then evaporating onto the cap, since I fixed the gaskets it does not happen anymore.
Old Dec 17, 2007 | 12:26 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I'll comment on this too. My high mileage '99, when I had the heads off a couple of years ago to replace the lifters, I found this yellow scum like stuff all over inside. It wasn't a lot, but looked more like a film on everything. I've only used Mobil1 and never anything else. It was an oily substance. I wrote to Mobil about it, but they said they had no idea unless I got a formal analysis done on it.
Old Dec 17, 2007 | 01:48 AM
vettegator005
That is a perfect description of what the inside of my oil cap has on it like a oily film. Wasnt really to worried about it because nothing has ever been wrong but just wondering. Thanks
Old Dec 17, 2007 | 01:49 AM
DeeGee's Avatar
DeeGee
Just what I was thinking although I'm no expert. Synthetic oil shouldn't break down so it might be water in the oil. it could be natural condensation if its a while since the oil was changed or the car has been idle for a while
If it is the early signs of a head gasket problem, best have it checked out. You'd have white smoke in the exhaust. A compression test will flag up any issues. Water and pistons dont mix well.
I just had exactly the same problem with my son's Camaro but we caught it before any damage was done. A strip down was expensive but saved the engine blowing. I'm sure the engine gurus will chime up but I'm just naturally cautious on engine problems.
Old Dec 17, 2007 | 06:31 AM
rws.1's Avatar
rws.1
it reads like condensation from short trips.
That is exactly why it is best not to start your car over the winter...
As noted by DeeGee it could also be early warning signs of a head gasket problem. BUT with only 49K that probability is rather low.
You might want to have it checked out sometime soon.
To Is this normal?
Old Dec 17, 2007 | 07:15 AM
vetter79's Avatar
vetter79
If your going to run that motor, run it for at least 20 min. to get rid of the condensation.
Old Dec 17, 2007 | 09:52 AM
Rollin's Avatar
Rollin
I would say if your oil looks good & its just on the cap, its probably just moisture from condensation. With colder weather or high humidity. I used to see that when I lived in Alaska, parked in a warn garage and cold outside make for condensation in oil & gas. Just a thought.
Old Dec 17, 2007 | 09:58 AM
gojo's Avatar
gojo
Watch your coolant level. You should not see any loss at all.
