gas tank button not working!!! please help!!!
Old Jan 8, 2008 | 09:30 PM
vinnyxgunz's Avatar
vinnyxgunz
Default gas tank button not working!!! please help!!!
all of a sudden this button is not working and i don't know what to do... i have no more gas and i don't know what to do... please help...
Old Jan 8, 2008 | 09:35 PM
PewtVette's Avatar
PewtVette
You should be able to release the gas door from inside the rear hatch.
Old Jan 8, 2008 | 09:37 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
you can pop the trunk and also pop the gas cap cover by pulling on metal lines hidden in the back.
PewtVette's Avatar
PewtVette
BTW, mine is the same. I don't hear the actuator when I hit the button. I haven't investigated the problem yet.
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
If you're sure its the button causing the problem shoot me a pm.......I've got one. I dunno, $7 shipped sound reasonable?
Old Jan 8, 2008 | 09:39 PM
The tab is located against the upper trim on the driver's side in the rear compartment. It has a tag on it labled Fuel Door Release.
Old Jan 8, 2008 | 09:42 PM
Big-Red's Avatar
Big-Red
St. Jude Donor '06-'07-'08-'09-'10,'13-'14
Look behind the drivers seat you should have two pull wires, one for the rear hatch and one for the gas flap. They will be somewhat covered by the carpet. At least for my Vert. Also check the fuses.
Old Jan 8, 2008 | 09:52 PM
vinnyxgunz's Avatar
vinnyxgunz
ok... and how can i find out if the problem is the button or the harness or something else...
Old Jan 8, 2008 | 11:18 PM
vinnyxgunz's Avatar
vinnyxgunz
i still can't find the wire...
Old Jan 8, 2008 | 11:37 PM
vinnyxgunz's Avatar
vinnyxgunz
got it... thanks guys
Old Jan 8, 2008 | 11:52 PM
egypt123's Avatar
egypt123
1. Pull off the center console.
2. Check to make sure the electric connector/plug is still connected the the fuel release switch. If it's not, connect it and try the switch. If it is still connected, ...
3. Disconnect the plug and get a paperclip or stiff wire and stick one end into the hot connector and the other end into the ground connector of the plug. This will short the connection.
If the door releases, you have a bad switch. If it doesn't release, then you have a bad release mechanism or an electrical issue. Also, check the fuse. If you have an OHM meter you can check to see if you have power to the switch.
Old Jan 9, 2008 | 12:09 AM
Oh 2 Fun's Avatar
Oh 2 Fun
Good call Egypt.....
Old Jan 9, 2008 | 12:28 AM
DefenderC5's Avatar
DefenderC5
If it's not the switch, check the fuses under the passenger side kick panel. Check the diagram for the fuel door release fuse. When mine didn't open, this fuse was blown.
Old Jan 9, 2008 | 01:48 AM
DeeGee's Avatar
DeeGee
Worth checking
Its minifuse #32
Old Jan 9, 2008 | 03:29 AM
97C5driver's Avatar
97C5driver
was your gas cap on correctly when you finally got the door open?
I let my brother borrow my car a while back and he didnt put the cap on right, whcih caused the fuel door to stick. i had to use the emrgency cable to open it but everything has been fine since.
Old Jan 9, 2008 | 09:59 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Looked all over mine and can not find the tab or the wire. Any pictures of where it should be?
Old Jan 9, 2008 | 11:35 AM
egypt123's Avatar
egypt123
In my FRC it's in the trunk compartment and I have to pop open the trunk to get to it. It's located up high around the wheel well, and if I recall correctly, it's tucked behind a carpet panel. It's not easy to find if you're looking for it for the first time.
To gas tank button not working!!! please help!!!
Old Jan 9, 2008 | 01:54 PM
vinnyxgunz's Avatar
vinnyxgunz
it is connected... but i'm just wondering if it's the button or the harness or the fuse... typically what is it... and how can i determine what the problem is?
Old Jan 9, 2008 | 02:01 PM
env00's Avatar
env00
Take a look at egypt123 post #11 in this thread, item #2.
I had a similar problem and turned out to be a non-connected gas switch -- when I changed out my AC/heater module (below the stereo) somehow the cable disconnected. The switch itself is less than ~$20 if I recall. I would recommend to check that first before the fuse.
Good luck!
Old Jan 9, 2008 | 02:50 PM
hotwheels57's Avatar
hotwheels57
If you've ever had your center console apart (shifter installation?), maybe the wire(s) got pinched or the connector damaged.
My fuel fill door would periodically not open with the switch, but I could hear it clicking. I pulled the manual release and checked for corrosion/broken spring that others have sometimes reported. There was none and the fuse was not blown.
I lightly lubed both the plunger and the end of the fuel fill door where it connects with the plunger (with white lithium). That solved the problem. However, to much lithium results in the fuel fill door opening at the most inopportune times.
