Clear Corner Light Options
Old Jan 12, 2008 | 10:33 AM
krm_wi_C5's Avatar
krm_wi_C5
Originally Posted by TheRadioFlyer
I'd love to tell you why it happened, but I have no idea. All i know is when I pluged in one to test it and turned on the car, all the gauge lights started flashing irraticaly. Almost like my car was posessed.
I exrocized the bulb and replaced it with the standard LED tower 3157 I was using before and the problem went away.
Thanks, I was going to order the SMT bulbs. I'll just go with the tower bulbs.
One more question. I noticed that AutoIllumination has different sizes on the 194 bulbs. Does anyone out there know if there is a bulb size restriction with the smaller bulbs in the front corners?
Old Jan 12, 2008 | 04:02 PM
krm_wi_C5's Avatar
krm_wi_C5
Anyone have any advice on the size of the 194bulbs? Do the larger diameter bulbs that AutoIllumination sells work in the front corners?
Old Jan 12, 2008 | 07:44 PM
eec8059's Avatar
eec8059
Yes. There is plenty of space for the oversized 194s.
As long as the base is 194 compatible
Old Jan 12, 2008 | 08:46 PM
krm_wi_C5's Avatar
krm_wi_C5
Thanks!!!
Old Jan 13, 2008 | 12:35 AM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
How many bulbs do you need and part #'s? thanks
Old Jan 13, 2008 | 12:48 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
you'll need (2) 3157 bulbs and (2) 194 bulbs
most of the autolumination bulbs will work. I'm using the "superstar" bulbs myself.
I think the only ones that won't fit are the "tower" series and 5-LED matrix. Everything else should fit and work well. The "Superstar" and Supernova bulbs would be perfect.
Old Jan 13, 2008 | 10:38 AM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
Are the Superstar" and Supernova bulbs a switchback bulb? If so where can I buy them ?
Old Jan 13, 2008 | 12:37 PM
hangpilot's Avatar
hangpilot
Anyone know if these Autolumination bulbs would work? They don't claim to be SMT style.
Eagle-Eye Tower (US Patent Pending)
3157 replaces 3057 3155 3357 3457 4157
11 Super-Power Wide Angle High Flux LEDS
These Bulbs have Advanced Patent Pending Control Circuitry Found in no Other LED Bulbs
These are the most advanced and brightest led automotive bulb assemblies ever produced.
More powerful, consistent color and more stable than any other automotive leds made.
1 Super High Powered 3 Watt Wide Angle Flux Forward Facing Led
10 Side Facing Wide Angle High Powered LEDS
Fits thru the standard 1" diameter hole.
Old Jan 15, 2008 | 03:05 PM
rpm462's Avatar
rpm462
Hey, on the Switchbacks....how do they work when the turn signal or flasher is activated? Do they stay clear or alternate amber and clear?
Old Jan 15, 2008 | 04:58 PM
jdmvette's Avatar
jdmvette
Night Owl for life
they are amber when the light switch is OFF.
they are white when the parking or headlights are ON.
they are amber when the blinkers are activated in either mode.
Old Jan 15, 2008 | 06:54 PM
rpm462's Avatar
rpm462
Thanks Jason...sounds pretty cool...guess will break down and order a couple then. The small bulb on each side, 194's, are you using LED ones there as well, and if so which ones are you running?
Old Jan 15, 2008 | 08:24 PM
jdmvette's Avatar
jdmvette
Night Owl for life
yea, i'm using LEDs there too. mine are the 5 LED matrix bulbs in amber.
Old Jan 16, 2008 | 08:34 AM
  #33
rpm462's Avatar
rpm462
Ok, couldn't stop myself, just ordered the switchbacks and the 5 LED Matix 194's!!
Old Jan 17, 2008 | 06:53 PM
  #34
krm_wi_C5's Avatar
krm_wi_C5
Well, I ended up with the 20 LED Tower II Switchbacks and the Amber SMT Tower III 194's. I'll post pictures when I install, probably in March or so. Thanks to Richard from Corvette Enhancements and Chris at AutoIllumination for your help!!
Old Jan 17, 2008 | 08:36 PM
  #35
stormrider's Avatar
stormrider
Do any of them stay white all the time until you hit your turn signals?
Old Jan 17, 2008 | 09:03 PM
  #36
krm_wi_C5's Avatar
krm_wi_C5
Only the switchbacks when the parking or headlights are on.
Old Jan 17, 2008 | 10:35 PM
  #37
jdmvette's Avatar
jdmvette
Night Owl for life
yes, i was thinking that they had sent me the wrong bulbs because when i fired up the car i was expecting to see WHITE drls with the lights off.
the only time they are white is when the parking lights or headlights are on. they are amber when in daylight driving mode. the LEDs still look very cool in amber, especially with the clear corner lenses.
To Clear Corner Light Options
Old Apr 17, 2008 | 01:19 AM
  #38
JKennedy1612's Avatar
JKennedy1612
jdmvette,
Where did you buy your front corners?
Old Apr 17, 2008 | 01:59 AM
  #39
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by JKennedy1612
jdmvette,
you'll find plenty here.
Old Apr 17, 2008 | 02:10 AM
  #40
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
Hey guys,
What's Corvette enhancements website?
Thanks,Tom
