Clear Corner Light Options
Old Jan 11, 2008 | 10:52 AM
krm_wi_C5's Avatar
krm_wi_C5
Default Clear Corner Light Options
I recently received a set of clear corners for Christmas. I am looking for the best lighting options, including the vendors. I have the new flasher harness from Richard, so LED's can be an option. I ran this same post a couple of months ago, but am running again just in case there is something new. I need to order the lights since I will be installing the corners soon. Thanks to all in advance for your responses.
Old Jan 11, 2008 | 12:23 PM
eec8059's Avatar
eec8059
I, and many others in this forum, use autolumination.com for lighting needs. That'll probably be your best bet.
As for bulbs, I use super whites; no LEDs. That works for me without problems, thus far.
Old Jan 11, 2008 | 01:19 PM
JohnTheStigGalt's Avatar
JohnTheStigGalt
This is what I've Autolumination Switchbacks in my clear corners:
LOVE the look!
Old Jan 11, 2008 | 01:28 PM
Iron Chef's Avatar
Iron Chef
St. Jude Donor '06-'07-'08-'09
CI 8-9-10 Veteran
I use autolumination as well. A bit pricey, but great product.
Old Jan 11, 2008 | 01:44 PM
slplank's Avatar
slplank
These are the specific LED's I have ordered based on input from members. I have not installed them yet but am looking forward to doing it.
3157 amber and White 27 LED SMT Tower
Try this link if it works, if not paste it in your browser
http://autolumination.com/3157_3156.htm
Scroll down to the fourth row of pictures of the lights. They are $19.99each
Old Jan 11, 2008 | 06:06 PM
jdmvette's Avatar
jdmvette
Night Owl for life
[imghttp://autolumination.com/images/auto_bulbs/3157whiteamber.gif[/img]
LOVE the look!
Old Jan 11, 2008 | 07:41 PM
midlifetoy1's Avatar
midlifetoy1
Default clear corners
LOVE the look!
Switchbacks for sure!!!
Old Jan 11, 2008 | 07:53 PM
maxvalley's Avatar
maxvalley
Are these plug and play - take out the old and install the new leds or do you need to do wiring work, flasher etc?
Old Jan 11, 2008 | 08:03 PM
krm_wi_C5's Avatar
krm_wi_C5
LOVE the look!
Do you know the exact part number needed for a C5? (For the switchback) Also, are there 2 bulbs in each corner? Which other bulb is used?
Old Jan 11, 2008 | 08:41 PM
jdmvette's Avatar
jdmvette
Night Owl for life
they're plug and play. they will cause you to have rapid flash, however, unless you install the LED harness from richard.
Old Jan 11, 2008 | 10:32 PM
hangpilot's Avatar
hangpilot
I have the switchbacks and was wondering if anyone knew how get white DRL's out of them? Other than by moving headlight the headlight switch to parking lights.
Old Jan 11, 2008 | 11:08 PM
jdmvette's Avatar
jdmvette
Night Owl for life
i think that's the way they're designed. amber when the switch is off, white when it's on.
Old Jan 11, 2008 | 11:12 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
LED tower bulbs are a good option.
DO NOT use the SMT style tower bulbs. For some reason they freak out the car's illumination.
Old Jan 11, 2008 | 11:24 PM
krm_wi_C5's Avatar
krm_wi_C5
Can you elaborate on the issue the SMT bulbs cause?
Old Jan 11, 2008 | 11:34 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Jan 12, 2008 | 12:09 AM
hangpilot's Avatar
hangpilot
Would it make a difference if the SMT bulb was a dual circuit type?
Old Jan 12, 2008 | 12:13 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I'd love to tell you why it happened, but I have no idea. All i know is when I pluged in one to test it and turned on the car, all the gauge lights started flashing irraticaly. Almost like my car was posessed.
I exrocized the bulb and replaced it with the standard LED tower 3157 I was using before and the problem went away.
To Clear Corner Light Options
Old Jan 12, 2008 | 12:20 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I'm pretty sure the one I tested was a dual circuit.
Old Jan 12, 2008 | 12:25 AM
hangpilot's Avatar
hangpilot
Thanks for the heads up.
Old Jan 12, 2008 | 01:27 AM
jdmvette's Avatar
jdmvette
Night Owl for life
good to know.
