(Question) How to increase Acceleration/Torque?
Old Jan 12, 2008 | 09:40 PM
Uncle John's Avatar
Uncle John
Originally Posted by FFIN90
Glad to see your interest in the Corvette. But if your already looking at doing the speeds you mention above, the 1st thing to get is a good life insurance policy.
He is in Canada.....sooooo. In KPH wouldn't 130-150 be around 85-95 Mph? Doesn't sound so fast to me. I drive those speeds everyday so the guy behind me doesn't run me over.
Old Jan 12, 2008 | 09:46 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
You want acceleration just slap on a blower the world changes fast
Old Jan 12, 2008 | 10:49 PM
Mr. Lau's Avatar
Mr. Lau
Haha thanks for all the help guys! I realize now that to get accleration, a bi-product would have to be top speed no doubt about it...but who cres I guess lol.
Oh and btw 130 KMh here is like.....fast lol our highway limit if 110 KMh .
Old Jan 13, 2008 | 12:05 AM
hightest's Avatar
hightest
Go for gears. You'll lose out on the top end, but you'll get to your top end alot quicker. I went from 2:73's to 3:42's and it felt like a 75 hp gain. Gears are also alot more fun if you're a light to light person.
By the way, I'm always in somewhere Alberta, I work in the patch!
Old Jan 13, 2008 | 03:31 AM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
Originally Posted by Cozmo
Rear gears.
this is the quickest, most cost effective way to go quicker
Old Jan 13, 2008 | 07:39 AM
LTCHAPPA's Avatar
LTCHAPPA
Get LT Headers and 410s.
Old Jan 13, 2008 | 07:57 AM
AU N EGL's Avatar
AU N EGL
Originally Posted by csexton
Keep asking those questions my friend. You are doing fine and good luck on your search for that perfect vette
Chuck
We all had "questions" before we found the right vette.
funny part is ppl ask lots of questions about How to increase HP or TQ, How to do this or that.
Then they GET in a vette, and push that right peddle to the floor, and then HOLEY Chit man. May be I dont need that EXTRA power.
No matter what you get you will be walking around all the time with a
Old Jan 13, 2008 | 08:21 AM
RSchleder's Avatar
RSchleder
Default Speed limit????
How nifty, your town has a 150mph speed limit
Old Jan 13, 2008 | 11:25 AM
4THTOY's Avatar
4THTOY
simple method, more cubic inches, larger engine=more tq, lower cost method, start with changing rear gears, won't "add" more tq, but will the tq you have to get off the line quicker, next change cam, than LT headers
Old Jan 13, 2008 | 11:51 AM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
All joking aside..........
HP is exactly equal to torque x RPM/5250, nothing more. All else equal, if you increase HP on an LS1/LS6, you're also increasing torque. If you ever see a dyno plot, you'll see that the torque curve and the hp curve cross exactly at 5250 RPM. You can't have one without the other. This is at the engine level.
At the rear wheels, things are slightly different. Cars use a transmission to lower RPM's and then there is a rear-end gearing to lower that even further. Gears work to reduce RPM, but increase torque, or the opposite. For example, first gear on an automatic is 3.06 (from memory) and the rear end is lets say 3.15. That means RPM's are being reduced by (3.06 x 3.15=) 9.639x, but torque is being multiplied at the rear wheels by 9.639 times. That is why, as most have suggested here, that by changing your rear end ratio to a higher number, you'll increase the torque applied to the wheels. Going to 3.73's would increase rear wheel torque by 18%, without ever having touched the engine.
Old Jan 13, 2008 | 04:17 PM
Mr. Lau's Avatar
Mr. Lau
Sounds like a plan Do you teach for a living?
Old Jan 14, 2008 | 02:06 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Canada= Metric
Old Jan 14, 2008 | 02:12 AM
  #33
jacks996's Avatar
jacks996
Jacks996
Originally Posted by Brandon619
, Procharger 8psi and 3.90 diff, FAST 90/90, Cam, good clutch, sticky tires, a little meth, I could go on and on .
this would do it
Old Jan 14, 2008 | 10:11 AM
  #34
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
The key to good acceleration is getting torque in the bottom end of the RPM range. Torque is added by increasing compression and Airflow through the engine. Without getting into serious engine modifications or FI, here's my suggestions:
- Long tube equal length headers. the longer the pipes the lower in the RPM range you'l benifit.
- Aftermarket Camshaft.
- Aftermarket exhaust (including high flow cats)
- Underdrive pulley
- Good intake setup (ported or larger TB is reccomended)
Yes, but if you claim it, modding your vette is kind of pointless.
